Oil/Wood
I’m looking for some related material (code, etc) to oil/wood burners using separate flues.
Originally Posted By: jcampbell
http://www.nachi.org/bbsystem/usrimages/w/woodstove.JPG ]
Jeffrey S. Campbell
http://www.maineshomeinspector.com
Thanks for that…it’s helpful…I can’t find anything that says it cannot be in the same flue in our local regs (doesn’t mean it’s not there, just means I haven’t found it), but had an insurance agent ask if a home had a single or double flue for the oil/wood and said he doesn’t know any insurance company that allows that, so I’m just trying to learn a bit more and see if that’s something I need to be taking a second look at.
Anyone else have any input?
Originally Posted By: phinsperger
Paul Hinsperger
Hinsperger Inspection Services
Chairman - NACHI Awards Committee
Place your Award Nominations
here !
Originally Posted By: dandersen
Quote:
Venting more than one appliance into a common flue is still permitted in some states and localities. Multiple use of a single flue is dangerous, especially if a spark or burning soot or creosote has access to the house through an unused opening. Additional problems with fluctuating draft can be experienced if a wood stove and an oil or gas hot water heater are connected to the same flue. Back puffing could extinguish the pilot in the water heater causing, at the least, an inconvenience.
http://edis.ifas.ufl.edu/FR018
Originally Posted By: rcooke
Yes it is allowed I believe here for oil and wood only not gas .
I had a wood furnace for years and it only had one entrance into the chimney
but the wood came into the bottom of the oil furnace flue pipe just before the chimney.
Roy Cooke Sr.
http://Royshomeinspection.com
