Hello,
We just had an inspection done on a home we are purchasing. The inspector used an infrared camera, and found what he believed to be moisture intrusion under many windows. He did not confirm anything with a moisture meter. I then emailed the pictures to an energy auditing company who then stated that they were certain the thermal images showed air leakages and not moisture intrusion. I don’t know what to do to be honest. I was wondering if some of you inspectors with LOTS of experience with infrared devices can chime in and tell me what you think-- moisture or lack of insulation/air leaks??
You will have to copy and paste this link-- thermal images are at the bottom of the report:
http://www.nspec.com/login/brown/report.pdf
An essential part of any infrared inspection is confirmation of thermal anomalies. While moisture intrusion and air leakage each have different “typical” thermal patterns, suspected moisture related issues should always be verified, whenever possible (verification can be done without a moisture meter if evidence of moisture is visible).
Neither the home inspector or the energy auditing company can give you a definitive answer as to the cause of the anomaly without verification.
Your home inspector indicates that he is Level-I certified through ITC (an internationally recognized thermography training organization). A level-I thermographer should be qualified to perform this type of analysis. He should have the tools and knowledge needed to verify his findings.
I would ask him to either present his verification or come back out and verify if he didn’t already do so.
Without testing equipment your basically just taking pictures with no definitive answer or true meaning available, nobody here can guess if any moisture is present.
Back up your findings with test equipment, whether moisture or electrical equipment, and not one product fits all situations either, its good to have an assortment, their cheap, but needed.
I bet you won’t do this again, everyone has to start some where, we all know this, nobody is calling names or belittling, but please learn the basic techniques to perform thermal imaging.
I assume many of us confirm/approach very similar.
If it’s faint I’ve measured the area with 2 meters… just to be sure as well. I assume I have responsibility to be sure “It’s wet” if I say it is… with or without IR, as I assume that there’s a decent chance someone’s gonna cut into/demo a wall/ceiling whatever. Also, as part of a QA program, I’ll set a calendar event to make sure the protimeter(s) are within tolerance.
The reports certainly leave some things to be desired and creates a number of additional questions.
As Chuck indicated, only the inspector can present his methods and proof of verification for active moisture. “Suspect” moisture as he terms in the report is not acceptable reporting for areas which were obviously readily accessible for verification via additional equipment in my opinion.
Where air infiltration occurs, moisture intrusion and condensation related moisture can also occur… but again these conditions must be verified with additional equipment.
Recommend you contact your inspector to provide his explanation of verification methods beyond visual and thermographic observations. If no further verification was performed, you will likely need to employ a more qualified professional to determine further.
Interesting thread here.
Posting a few shots below.
Notice how he only suspects but in number 4 is positive .
My guess is he based that on the temp at the baseboards and streak pattern.
Also noted he has a large box fan on the rug…maybe he used that ?
Do not use ir but even I know a moisture meter should have be used to confirm.
He sure does go detailed on the GFCI trip time however.
I agree Bill, what a cheesy Inspection report that is.
I am not into IR, but can say that it all looks like lack of insulation, foaming of cracks and lack of caulking providing air infiltration.
Report says temperature of 41-62, did he know the exact temp.?
Static water pressure 66-80. Sounds like the optimum not the existing condition.
I’m extremely unimpressed at the quality of the end product and lack of useful information for the stated cost of inspections. Imagine being an out-of-state client not able to attend the inspection… :shock:
Yes-- looking back I am not satisfied much with his inspection. It didn’t even dawn on me until a couple days after that he hadn’t even gotten onto the roof to check anything!! I am so frustrated, but we are in a pickle right now. We felt better after talking with the energy auditing company, so we had decided to move forward and are now past the inspection period where we could back out. Have any of you ever gone into a house after the inspection but prior to closing to check on something for a client? I would love to get some moisture readings before signing on the dotted line.
I find myself extremely intolerant of stupid crap this week. It is coming at me from all directions. I apologize for my intolerance, but I’m not going to change my ways, sorry! If you’re wrong I’ll tell you so.
The information should be pretty easy to get… you’re certain no moisture meter was used? Seems a bit strange…
I would suppose if possible moisture intrusion was mentioned in several areas of your potential purchase, it would seem at least prudent to follow up on now versus later… all things being equal, better safe than sorry, that’s why you hired the gentleman in the first place.
Anyway, you can probably do a quick search of guys in your area or post your geographical area and a request for help here.
by the way… you should see a picture of a meter if things are… wet.
some of us verify post inspection repair completion or do a complete inspection for customers that aren’t confident with prior inspection reports
Dan Bowers works the KCKSMO market
I would consider this an unfortunate lesson learned and would buy the house without any further consideration.
This is based upon the facts listed in the inspection report.
There is nothing there that would constitute a significant defect that requires immediate evaluation in a new construction building. There are no other associated conditions with this alleged moisture intrusion. All thermal anomalies appear to the air leakage (which could become a moisture condition in the summertime, not in the wintertime).
These are scans that I took of totally insignificant issues in a new construction property yesterday. If you look outside the obvious anomalies, you’ll see things such as thermal bridging and thermal bypass that are way beyond what are posted in the inspection report in question.
These anomalies do not require repair based upon the standards that my inspection property was constructed.
I would recommend that you have this Inspector come back and do the moisture testing that should have been done before he put this stuff in the Inspection report however…
