Mold testing done when something is found
I am adding mold sampling/testing as an add on. Scenario: I am performing a contracted Home Inspection only. I see what may be moisture, or mold type material. I would then ask the client if they would like me to test the air and sample the mold, providing a cost. They say yes, how do you handle adding the service. I realize I just send the mold contract and have them pay. Do you ussually stop the inspection handle the new contract, then proceed with both? Sorry, I know it seems like a no brainer, but I always prepare for handling add ons at the last minute. Any advise would be welcomed. Thanks
First question: Does your State regulate and/or License testing for Mold?
No, Ohio does not have licensing requirements.
i ask before i send the pia. i don’t sample the air but if i see microbial growth, i suit up and take tape samples. $100 to suit up and take the samples, the lab charges $25 per sample to test. this is what i use ai for, analyzing reports. they are great at that and give you the links to the epa guidelines to verify they aren’t hallucinating.
Really depends on what software you are using. I use spectora and adding a service it very easy and only takes 30 seconds to do. It automates the process, it will create the new agreement and add the cost to the original invoice.
If you are not using any type of administrative software, you might look into it. Time saver for sure.
You could follow CDC guidelines and let them keep their checkbook in their pocket. Recommend remediation and move along. :slight_smile:
Per CDC recommendations:
Cleaning
If you see or smell mold, you should remove it. You do not need to know the type of mold. If mold is growing in your home, you need to clean up the mold and fix the moisture problem.
Home testing
CDC does not recommend mold testing.
The health effects of mold are different for different people so you cannot rely on sampling and culturing to know whether someone might become sick. No matter what type of mold is present, you need to remove it.
Also, good sampling for mold can be expensive, and there are no set standards for what is and what is not an acceptable quantity of different kinds of mold in a home. The best thing you can do is to safely remove the mold and prevent future mold growth.
Yes sir!
Air quality sampling is OK, but I do not recommend surface swab test.
I don’t care what type it is (red-green-Chinese-Italian).
It’s mold gotta go.
Bleach is only effective for surface mold, it doesn’t effectively (or at all) penetrate porous materials. To remove it, soap & water, vinegar
or Kevin Leonard’s special PBR Mix.
If during inspection I suspect or discovered mold I simply recommend remediation unless the client needs the result for legal purposes.
I offer indoor air quality/mold testing and radon testing when I schedule an inspection. If they pass and I find potential concerns, I will explain what I am seeing and once again let them know that I offer testing if they are interested. I don’t pressure them as I feel that it can come off as being predatory. If they decide that they want it tested, I have them read and sign an indoor air quality/mold testing addendum and send an invoice from Square. Once the inspection of complete and the paperwork is taken care of, I perform the addtional testing.
This was my thought too
Every home has mold in it. It’s the nature of the beast. 1000s of different kinds of mold. Only a handful are of concern.
All of the houses I’ve tested, except one, came back positive.
