Kilometers, Provinces, Postal Codes.
THANX NICK!!![]()
Hi Nick when will the site be up and running .Just tried it for my area and it comes up with nothing
Worked for me Rob.:o
Worked for me too! Thanks Nick.
Worked for me, I just randomly checked 30 Canadian cities.
Ok it works but only with postal codes if I type in london ontario it comes up with no results found.Works fine if you know the postal code but not all clients will know the postal code of the area they are looking in.
I had no trouble .
begin, simply type a postal code or city and state/province into the box below:
“City, State/Province” or Postal Code:
Search Range:
Below are your search results, listed by distance from London, ON, Canada. Feel free to search for home inspectors again.
Please note that in an attempt to prevent spam, you can only send e-mail directly through the InspectorNow website.
David T. Andres
Grassroots The Inspection Specialists, London
» David T. Andres is based out of London, ON.
Website: grassroots.ca
E-Mail: Send David T. Andres an E-Mail
Phone: View David T. Andres’s Phone Number
Phone: (519) 451-1322
Manfred Lesser
ml designs
» Manfred Lesser is based out of London, ON.
E-Mail: Send Manfred Lesser an E-Mail
Phone: View Manfred Lesser’s Phone Number
Phone: (519) 495-2794
Here are two of many .
Roy Cooke
Same for Simcoe and others, it would be better if all towns worked and not just postal codes, what about it Nick???
I just tried London,on three times worked good then tried Simcoe,On and it worked also I used Captial ON with one and small on and it worked . I wonder why you have trouble .
Roy Cooke
Rob put the , after the city and then the province, worked this way for me.?
Just tried my home address Thamesford Ontario N0M 2M0 and it did not work,then I entered just the postal code N0M 2M0 and it worked. Like I said before not everyone knows the postal code for the area they are looking in.
Ok Chuck tried what you suggested about placing the,after the city and it work.Some people would not think of that which could be a problem
Ya, hopefully they will read the directions and do as it says!![]()
</IMG>
Well if their like me they will not and that is where the problem lies
Well I was feeling all warm and fuzzy being included in the Great NACHI family.
You can imagine my crushed feelings when Edmonton, Alberta came up with
"Unfortunately we could not determine where you were trying to search. Please go back and try again. Make sure to input a valid postal code or city and state/province combination.
You can find this page again by visiting http://www.InspectorNow.com and searching for “Edmonton, Alberta, Canada”
It only works when I input the postal code.
Vern, you have to put province in the same format as state, i.e. AB for Alberta, and not the full name. In this case it works fine. You do not need specify Canada.
OK thanks
