We are asking that everyone send their comments and suggested additions to us to help us improve it. If you find errors let us know. If you have pictures to go with your suggested additiions, please send those too. We are working on making the course more robust… with your help. Please contribute by emailing [email protected] Contributors will be credited on the last page of the course
Interesting course, and well done so far.
I will send a couple pictures of a home I recently did that was sliding down the hill…
And I like the way its already added to the CE credits.
http://education.nachi.org/show.php?element_id=428&course_id=22
‘There should be at least 2 vents to the outside in enclosed areas such as crawl spaces and at least one vent for every 300 square feet of floor area.’
This is not recommended in northern climates
Overall a nice little course but I there was far too much SOP stuff included in a ‘structural’ course. Put the SOP stuff in an SOP course and keep the structural course … well structural.
Typically, collar ties are placed in the upper third of the roof. Collar ties are not meant to prevent the horizontal spreading of the rafters or act like rafter ties - they are intended to prevent uplift from wind and really nothing more.
Rafter ties, which can be ceiling joists are placed near the bottom of the rafter and help to prevent the horizontal spreading of the rafters .
Paul, thanks… all good points. Thanks! Here is my thinking on it:
I normally find cold joints in poured concrete to be diagonal, not horizontal. This being because the chute of the concrete truck stays fairly stationary and so the concrete slumps to the sides on an angle then cures some before the next truck arrives.
I can’t find anything on having crawl space vents not being recommended, even if northern climates.
I like the idea of adding a reminder for inspectors to look for missing blocking, like under walls running parrallel but between joists. I can’t find anything about cross bracing though. All I find are arguments that cross bracing does nothing structurally other than perhaps disperses some of the live load over a greater number of joists. I can’t find any reference to them being required anywhere.
We tried to use the structural course to first and foremost remind inspectors to stick to the SOP and not crack analysis which is not their job (and in fact is probably a criminal offense) to do perform any sort of crack analysis (engineering services).
They help prevent rafter spread. First of all they are called ties, implying that they are under tension, not compression. Second of all, code permits them to be 1" by 4". Now a 1" by anything is useless under compression but fine under tension. Third, having lived in snowy parts of the world all my life, my own roof’s collar ties are under tremendous tension when the roof is supporting a heavy snow load. The ties suffer tension because the rafters are trying to spread.
[FONT=ItcKabel-Demi]“Collar tie. A horizontal member used to tie a pair of opposing rafters[/FONT]
[FONT=Times New Roman]together. May be high to hold the upper joint together or may be low[/FONT]
[FONT=Palatino-Roman]to serve as a ceiling joist. Also called a collar beam.”[/FONT]
Collar Ties up near the ridge should not be in tension from rafters spreading unless there is a problem … like a change to a cathedral ceiling which removes ceiling joists acting as Rafter Ties. Common problem with retrofit cathedral framing when the ridge plate isn’t swapped out for a posted ridge beam.
