Newer SD 200 amp main service panel. Most of the grounded & grounding conductors were installed appropriately on the bus bars. However there were two isolated (bonded to panel) bus bars on both sides, with a few grounded & grounding conductors installed there. Now, I know the grounds are o.k. here, but what about the neutral wires and/or grounded conductors? Do the neutral wires need to be installed at the main neutral bus bar(s)?
Those neutrals conductors are not permitted on the EGC bus even in a service panel as shown in that photo. I see a main breaker, is this the service disconnect?
Alwaysa green doomed or green screw that is sized to fit only that thread on the panel. Will not fit any other entry.
Am I correct in my statement Jim.:roll:
