Use this thread to discuss the entry New article on meth labs at the InterNACHI Blog
I might add that corroded propane tanks strewn about the yard, blister packs from OTC ephedrine products and match striker pads torn off match packs as a tip off. These properties are often booby trapped and will contain hazardous chemicals sometimes even explosive. The question for inspectors suspecting the property is a former meth lab is not about whether it should be tested for meth but whether they should even continue to inspect it at all.
