Builder’s rep told home buyer- thats what the town wants- in regard to an asphalt driveway that in my opinion, looks like it may have been installed at less than the desired temperature…anyone have any gurther insight on such product or are we all in agreement to call BS?
Large gaps oberved between the aggregate in the new construction asphalt driveway. Water may settle in these areas causing premature deterioration, especially during colder weather when moisture may expand/freeze in said areas.
Porous Driveway. Eco-Friendly or Milled asphalt. Old asphalt that is crushed into gravel, which, when compacted, hardens or binds. Use to see lots of them.
Having run an asphalt company for some time my opinion is BS From this picture the material appears to be a product that does not have the appropriate amount of mineral aggregate in the mix. I would contact the city if you are not familiar with the city specifications.
In appearance it looks like “porous asphalt” which is a specialty drainage type asphalt. Which I have seen installed as part of a storm water management system. For this type to be installed, there would have to be a reason. I agree with the above post, the aggregate mix is suspect and the city may have a hand. But, not enough photos or information. If the aggregate was not loose, I probably would not call it a defect.
