I know this is not correct, but I need the words that how to explain what is incorrect here.
This builder put the windows like this through out the house. and I think its missing the outer trim.
Can someone please help me to identify the problem on this window install?
AHHH, the builders all time favorite excuse “it passed Code, everything is fine”.
It’s not okay, (other than an honest builder Rep/supervisor to oversee/correct issues or even better make sure it is installed right the first time) you need the siding and/or window manufacturer installation instructions as your definitive source. In Florida installation instructions should be available on site.
It appears to be a standard install, provided this is a fin window. Both the siding manufacturer and the window manufacturer would give guidance here. I think you may have showed up late to your own party.
That is just a different type of window jamb detail and still has a j-molding. If the siding is left with a gap for expansion, like they should, your bugs will still go behind it.
When I see vinyl siding like your first picture that is concave like that, it means to me that it is a cheap siding and will make it look worse inside a J-mold like that.
I agree. It looks like a standard vinyl window with built-in J-Chanel to me as well. I’m not seeing a defect in Asim’s picture.
the window frame has a one inch deep flange around the perimeter. it is flashed to the wall and then the vinyl siding edges tuck into the flange (J chanel) to hide the edges of the vinyl siding.
