You mention LED bulbs in the narrative, but show no clearance distances in the graphic.
Since most everything is LED nowadays, this should be corrected in the graphic, and if not an issue, that should be stated as well.
The way the measurements are shown is incorrect. They should be from the plane of the shelf.
Do these artists do any research before creating these?
Yes, the clothes stack.
Image updated: Closet Lighting - Inspection Gallery - InterNACHI®. Hit refresh. Thanks fellas!
@gromicko Does it help to have the lines plumb/vertical and level/horizontal to be more clear about the distance to nearest point of storage?
Yup…
The measurements in (Black) are only accurate for a piece of paper on the shelf. Any other item(s) on the shelf would be vertically higher up, thus closer to the luminary along the plumb line distance.
