Excellent work.
The graphic looks good, but the description of what it does is for sloped roofs and prevents water entering in behind the wall covering and damaging the wall structure behind.
Kickout flashing (also called diverter flashing) is installed at the lower termination of a roof-to-wall intersection — specifically where a sloped roof edge meets a vertical wall and the wall continues downward past the roof eave. Its function is to divert water away from the wall cladding and into the gutter, rather than allowing runoff to sheet down the wall behind the siding.
Run thru ChatGPT? It’s got the indicative AI dash. This is good, I word smithed it down a bit more and used it my report gallery. Thanks.
Excellent, I replace the graphic that I was using.
Look great, Zac!
