New image added to the free Gallery: Property Drainage Using Swales
Nice work.
Depending on the number of acres that drains onto the property, it may require someone with hydraulic engineering experience to determine the width, depth and slope of the swales. As a side note redirecting surface water onto a neighboring property can get you sued. You could argue the water always ran through your property onto the neighbors property, but concentrating the water into the swales will likely increase the water flow rate, which increases the ability to cause erosion.
