Beginning studies and mock inspections
Needed a break…
I’m trying to find something right with this…
Welcome to the forum, Dave!
There is snow on the roof! ![]()
hope this is not your house or next door to you
This is a good time/place to start practicing how you describe deficiencies.
Tell us what’s wrong like you would for a client and get some CC.
if i was starting with the failure ,would want to know if cracks in mortar were there before failure and if so why was nothing done to fix .
then before this looks like sub standared construction note 2x4 roof trusses
and no bracing at all i would not walk on this roof let alown have snow load !!!
Roof rake edge flashing looks appropriate.
It’s the RIGHT kind of example to use to show exactly what NOT to do when bringing overhead service into a dwelling.
Chuck’s suggestion is perfect - use it as a learning tool to develop solid narrative(s) for these deficiencies.
Thank you all for the feedback and input. I didn’t include the image of the service drop being directly above the clients hot tub and having less than 10ft clearance.
Documented, head scratching complete…moving on.
Cheers,
