I ran across this today in a 16 year old house. All of the band boards were on sill plates, except for this 14 foot section. I know that a treated sill plate keeps the band board from rotting. There are shims underneath the band board so that it isn’t in direct contact with the masonry block. Is this OK? If not, what could I say is wrong with it? Thanks in advance.
I blow the picture up and I can see this contraption on the right near a wood frame of some sort and it looks like a tie down wrapped around the joist. I do not recognize it.
The joist span is 2’ O.C. based on the length of those two bricks, and I see the shimming which looks like back to back cedar shingles used normally for shimming things like that.
But, this has got to be the most unorthodox type of floor framing I have seen in many years.
Obviously that was a crawl, and how did everything else look?
Surprised to see that friction fit batt insulation has not fallen down yet. Was there a kraft paper holding it up?
Everything else was pretty much normal. There was sill plate throughout except for this one section. It’s unusual to see joists hangers here in production housing. Batt insulation is typically supported here with metal hangers. They look like a straight section of coat hanger and often fail over time.
