Originally Posted By: jhugenroth This post was automatically imported from our archived forum.
Speaking of orientation, the best camera I’ve ever had is a Kodak CX 7330. When I turn the camera sideways, it automatically orients the picture properly, so I don’t have to do it on my computer.
Originally Posted By: jwortham This post was automatically imported from our archived forum.
Quote:
If too much heat is applied or if the plastic is heated for too long a time, the molecular chains break, causing permanent property degradation -- particularly toughness. Continuous pressure (bending or deforming) on a molded part also causes the chains to slide over each other, resulting in creep, or cold flow, which can seriously affect part dimensions.
Seems to be the natural tendency of plastic to continue to change under pressure from what I can tell.
Originally Posted By: rbennett This post was automatically imported from our archived forum.
“plastic to continue to change under pressure” Very much a problem when someone uses tight tywraps, clamps, staples to secure wire and cables, In some telecom areas - no tywraps at ALL - Just lacing
Originally Posted By: tschwalbe This post was automatically imported from our archived forum.
I would be more concerned with the fact that it looks like they are not put sheating or vapor barrier back. I would not be surprised if they just put siding across the opening.
Originally Posted By: dedwards This post was automatically imported from our archived forum.
Looks like a Fernco clamp. It is used alot when changing from cast iron to PVC and according to their website it is used for cast iron to cast iron or Plastic to Plastic.
Originally Posted By: pdickerson This post was automatically imported from our archived forum.
I don’t see any issue with the clamp, but I would sure like to know how they are planning on repairing the wall. Has the building inspector approved this?
