not convinced
thank you, to all who positively contributed to this thread! i learned something else from oakwood homes yesterday. apparently, there are two types of modular homes: on-frame and off-frame. the first type is constructed similarly to a mobile (manufactured) home, being wheeled onto a site, supported by masonry piers and a permanent masonry foundation. the wheels and axles are removed, but the steel framing stays. as mentioned above, these are built to state and national building codes - not hud specs.
the off-frame modular is, basically, a stick-built house with no steel framing (unless otherwise specified by designer) and no concealing vapor barrier. again, this type is built to state and national codes.
so, not only is there a difference between modular homes and mobile/manufactured homes, but there also is a difference in modulars alone.
i hope this helps somebody out there as well. it’s good when we learn something!
“Live as if you were to die tomorrow. Learn as if you were to live forever.”
― Mahatma Gandhi
**“I’ve learned that people will forget what you said, people will forget what you did, but people will never forget how you made them feel.”
**― Maya Angelou](Maya Angelou (Author of I Know Why the Caged Bird Sings))
Brother Roy,
It has been my sincere pleasure watching you “evolve” over these last two years! Thank you for taking the time and trouble to research these facts for us and for sharing your knowledge with us.
You are a true asset to InterNachi:p
warmest regards, Frank:nachi:
If you are afraid to show the link for Modular Homes it is OK.:wink:
At 62 yo not a lot of evolution left in these old bones.
Thanks !
Nice Answer Roy :slight_smile:
In Missouri, modular homes can be manufactured homes, but the plans have to be approved by the State. How the home is tagged is the easiest way to know the difference. If it has a metal tag on the rear outside corner, it is for sure a manufactured. If no tag, always double check with the list of homes on the Missouri Housing Development Commission website. It is the appraisers job to determine this, not ours.
Disregard the label, discribe how the home is built then talk to the client verbally about some of the stigmas attached to these types of homes as well as the potential difficult resale down the road, your client deserves the whole story.
Even though these types of homes can be just as well built (in many cases better) unfortunately they still have the stigma…Both types.
I think, at times, we get wayyyyy to hung up on terminology. If you take a bicycle and turn it into a motorcycle, that meets or exceeds all standards, should it be called a motorcycle and left at that? Or should the mechanic inspecting it tell the potential buyer the whole story and talk about how it might be hard to sell in the future?
It’s not my job to talk to the client about resale possibilities. It’s my job to inspect for defects and report.
Do as you wish though.
