Noteworthy defect?
…Removed for confidentiality - Thanks
Defiantly If I was buying this home and got water intrusion you can be sure I would be upset with the home Inspector .
It needs to be noted so the purchaser can understand there is going to be repairs needed … Roy
Thanks for your input Roy. I definitely value your opinion. :slight_smile:
A.M.
Any missing flashing should be noted on the roof cert. It is impossible to tell if it is an active leak from the outside. Note the missing/damaged flashing and let the insurance company and client work it out.
That’s the kind of answer I’m looking for Kevin. Thank you!
