Can I inspect homes in Ohio if my business is in Pennsylvania?
Yes you can, but licensing is on the way, so after it goes into effect you’ll then need to be licensed to legally perform home inspections in Ohio.
Thank you. This helps a lot. I have just started my Business here in Pennsylvania. So this is all new to me.
The real question is, can you inspect electrical panels in Ohio?
What do you mean?
Uh oh!! . . this should be fun
The Butler!
Or new construction.?..
So from what your saying I can inspect in Ohio until they start the licensing? Is there anything I should know that may be different from Pennsylvania Inspections?
Yes, you can legally inspect a house in Ohio until they come up with a date to enforce home inspector licensing, whenever that happens you’ll then need to be licensed in Ohio to be a home inspector, now whether or not your qualified to inspect a house, whether that be in Ohio or anywhere else is a whole other matter.
As far as anything different from inspecting in PA, I can’t answer that as I’ve never inspected in PA and I’m not sure if they require home Inspector licensing or not, but, a house is a house.
Thank you.
