Okay, I know this is a water heater...
Originally Posted By: kpetersen
http://www.nachi.org/bbsystem/usrimages/I/IMG_0147.JPG ]
Originally Posted By: jhagarty
Induced Draft Fan.
If the unit is LP or Natural Gas fired, the pipe should terminate at the home exterior.
Joseph Hagarty
HouseMaster / Main Line, PA
joseph.hagarty@housemaster.com
www.householdinspector.com
Phone: 610-399-9864
Fax : 610-399-9865
HouseMaster. Home inspections. Done right.
I agree. It is a gas unit, I’m just wondering what they were trying to do with that thing.
Pete
kpetersen wrote:
I agree.
It is a gas unit, I'm just wondering what they were trying to do with that thing.
Pete
Death by Carbon Monoxide (CO) Poisoning?
Joseph Hagarty
Phone: 610-399-9864
Fax : 610-399-9865
You’ve got that right.
They have a furnace (also gas) chimney that is so badly corroded that there are pinholes in it inside the attic space. It's a good thing that this house is in FL. The furnace doesn't get too much use.
Also, the vermin have added quite a bit of ventilation by chewing some well placed holes in the walls.
Originally Posted By: rcallis
This is a power vent water heater, it eliminates the need to have a chimney vent or a flue thru the roof.
But it still needs to terminate thru an outside wall and maintain clearences from windows, doors, etc.
Reggie
Originally Posted By: jwilliams4
What happens when “Dennis” knocks out the power and the fan
doesn't work -- and the water heater comes on?
"not just an inspection, but an education"
Originally Posted By: whandley
Most of them are equipped with a 24 volt air pressure switch. The unit will not begin the ignition sequence until the direct vent fan system is up to normal operating speed. Great question Jae!
Even better answer! Thanks, Will
“not just an inspection, but an education”
