I was looking at a house built some time in the 1930’s. Some of the original plaster walls and ceilings had been replaced with rock. One odd thing though. The ceilings throughout the house all had this rippleing effect where the plaster is sagging between between the joists. I’m pretty sure the ceilings were plaster. What could be causing this ? http://www.nachi.org/forum/attachment.php?attachmentid=48181&stc=1&d=1316274355
In a lot of old plastered ceilings of old homes, the plaster sometimes starts loosing it’s bond to the wood lath and starts sagging.
Always some with the bright idea to sheetrock it and use 3/8" drywall cause it is easier and light weight. When screwing to the lath, half the screws miss the lath due to the cracks inbetween and don’t hold crap. The weight of the loose plaster will make it sag.
Sheetrock ceilings over plaster on lath should have 1x3 strapping screwed to the ceiling joist and hold the drywall.
That would be my best guess to the problem. :)
The ceilings were textured (no popcorn though) in some rooms. The others were flat with varring degrees of the same type of sagging along the uniformly spaced outlines of the joists, and kinda hard to photograph. When I pushed back on the a few areas they were solid, like plaster with a layer of rock over it.
I have seen the after effects of this type of ceiling failure. The cases I have seen or dealt with directly, were all catastrophic failures (almost no warning, and the ceiling fails).
Jamie thanks. I just spoke to Philip (who got back about an hour after I called him on a saturday) and gave he gave some me some insites as whats goung on with this ceiling. I hope he keeps adding to his site. Thanks to all here you’ve helped to cofirm my thoughts on whats going on with “pillowing affect”.
