Open hot on outlets?
I’ve inspected 3 houses this week and all of them indicated an open hot after testing the outlet below kitchen sink used for garbage disposal. Disposals all worked fine but when tested they all showed open hot. The fact that they all showed the same thing in the same exact spot am I crazy? Is this normal or is it a defect? I’ve never ran across open hots before.
Sounds like it’s switch controlled and the switch was off.
Wow I feel stupid. That would make sense. Appreciate the help. Glad I asked….
Ask away that’s why we’re here.
its only stupid if You don’t ask, You don’t know till you know…now You know…
Also anytime we see an issue using a testing device, we check with another device.
