I am unable to get a signal on my computer. I am using my TREO.Question:What is the safest way to open or disconnect a main switch, fused type or CB?I suggested using the left hand while standing to the right to operate the devce to turn it off.I will search Google but would appreciate seeing other opinions.
Common industrial practice is to stand to either side of the device being operated, facing away from it and operating with either hand as convenient. Depending on the device being operated (fault current available, etc.) , Arc Flash requirements may dictate special clothing and other Personal Protective Equipment.
For houshold level stuff, you just want to position yourself wherever will minimize your exposure if a fault should occur.
I thought it was extremely poor practice for a H-I to throw a main breaker. I have no idea why one should.
You are correct. An HI would never throw a main.
Joe is not a Home Inspector, he’s a master Electrician.
Just wanted an opinion. thanks:
Last two paragraphs:
Lastly and possibly most importantly, the HVAC technician was standing in front of the motor controller enclosure as he operated the control switch.
The failure of the control switch was an abnormal event that could have happened at any time. However, equipment design that allows placement of a control switch on the cover of a motor controller enclosure normally places the operator directly in front of the enclosure. In this incident, had the control switch been located on a separate control panel away from the contactor enclosure, the technician most probably would not have been injured.
Or, if he had been able to stand well off to one side of the controller, his injuries might have been minimized.
Bill, the building maintenance worker who had attempted to switch the circuit breaker to the OFF position, was also standing in front of the panelboard as he operated the circuit breaker. Standing directly in front of the device placed him in jeopardy and he received burn injuries when the explosion occurred. Proper work practices must be used all the time so that it becomes a habit. Most of us stand and look at the switching device as it operates. However, the building maintenance worker and the HVAC technician probably will never operate a switch or circuit breaker again while standing directly in front of it.
The next time you operate an electrical device, think about this accident and don’t let it happen to you.
My wife would say leather glove, safety glasses and looking away … if you can’t get the sparky who wired it to turn it on. A few bolted faults on range circuits will make you agree with that. She does have some gloves with burn marks.
Thanks Greg, here are a few videos with information about arc flash hazards
Project Hanford Lessons Learned
Electrical Lessons Learned
95I020 Screws Penetrate Electrical Wiring
95I029 Improperly Wired Portable Transformer Causes Shock Hazard
95E033 ITE K600-S Breakers
95I035 Electrical Arcing Of 480V Circuit While Troubleshooting
95E043 Unsafe Power Strips Sold With Counterfeit UL Mark
95I047 RCT Receives Shock While Starting a CAM Vacuum Pump
95E049 Vacuum Circuit Breaker Interlock Defeat Possible
96I005 Potential Shock Hazard From Eberline Radiacs
96I006 Snow Buildup Results in Downed Utility Lines
96E010 Fluke Multimeters May Not Indicate Correctly
96I015 NEC Violations Should Be Identified and Corrected Quickly
96E021 Residue From Old Electrical Wires Can Cause Problems
96I023 Damage to Electrical Cords May Not Be Obvious
96E024 Nelson Switchgear Poses Potential Electrical Safety Hazard
96E040 Water in Transformer Causes Short Circuit
96E041 Electrical Shock Leads to Shutdown of Lab
96E042 Ungrounded Transformer Installed in New Fan Controller
96I050 Improper Electrical Labeling Caused Near Miss
96I055 Electrical Shock From CAM On Ungrounded Cart
96I056 Replacement Screw in Electrical Box Cover Arcs and Melts
96I060 Six Electrical Incidents - Are We Really Working Safely?
970004Y Electrical Shock and Flashburn Incidents
970009Y Bayco Products Work Light Recall
970013B MO-921 Electrical Near-Miss
970026B Undocumented Electrical Jumper Causes Mild Shock
970030Y Maimed Extension Cord Causes an Electrical Short
970036Y2 New Heating Unit Switch Destroyed by Short Circuit
970038Y CPSC Recall of Holiday Lights
199812 Authorized Worker or Controlling Organization Lock and Tag?
199815 Dry-Type Epoxy Transformer Failures
199816 Electric Shock During Response to Floor Valve Alarm
199823 Serious Flash Burns from Electrical Arc
199827 Control Room Fire Shutters Activated Due to Procedure Noncompliance
199830 Maintenance Must Be Properly Controlled
199834 Potential Electrical Safety Hazard Eliminated
199908 Interruption of Plant Public Address and Telephone System
199914 Electrical Shock from Indicating Lights
199923 Reclosing Tripped Electrical Protective Devices
199924 Look for Hidden Dangers Before Assisting in Casualty Control
199925 Fluorescent Tubes and Their Ballasts Should be Rated the Same
199926 Exterior Security Light Causes Structure Fire
199928 Check Electrical Equipment Deengerized before Working near It
199931 Electrical Maintenance Damages Computer Infrastructure
199940 Electric Shock from Old Deteriorated Heat Trace
2000-04 Ground Fault Circuit Interrupter Testing
