How many have seen this on new Builds?
http://www.gp.com/build/product.aspx?pid=6403
Nautilus™ Wall Sheathing
http://www.gp.com/build/images/products/nautilus_wallsheathing.jpg
Nautilus™ wall sheathing is an entirely new system with a pre-applied, weather-resistant barrier. That means the OSB wall sheathing is protected against rain and moisture from the time it arrives on the jobsite. This saves the extra step of installing a building wrap, which can translate into savings of time and money for you.
http://www.gp.com/build/images/products/nautilus_logo.jpg
Contact Sales
For sales information, call toll-free 1-877-437-9759.
http://www.gp.com/build/images/features/nautilus_chadbell.jpg
“Once the sheathing is installed, the weather barrier is installed too, so you don’t have to worry about heavy rains or moisture issues before building wrap is installed. Georgia-Pacific has simplified wall sheathing and weather barrier installation for me and my crew.”
Chad Bell
Blue Sky Construction
Gainesville, Georgia
All You Need Is A Framing Crew
- Installs like typical OSB wall sheathing.
- The nailing guidelines on the OSB panel are visible.
- Overall, a faster and more efficient installation process than a two-step sheathing/building wrap installation.
Fewer Air Leaks – Greater Energy Efficiency
Once your wall panels are up and the seams are taped with the code-compliant Nautilus seam tape, the structure is better protected from air leaks, helping improve energy efficiency. And you get improved protection against moisture because your structure is dried-in more quickly.
Better Looking
Our patent-pending OSB wall sheathing product is more uniform and consistent than what you typically find with the installation of a separate building wrap. The weather-resistant barrier is fully adhered to the panel, reducing the risk of wind damage. That’s a better reflection on you and the quality of your work.
Code-Compliant
Both Nautilus wall sheathing and Nautilus 3" seam tape are code-compliant.
http://www.gp.com/build/images/callouts/nautilus_shell.jpg
The nautilus is thought to be nature’s most inspired design. Its two-layered shell gives it double protection from the elements… not unlike the two-part construction of its namesake,
*Georgia-Pacific Nautilus™ wall sheathing. *
http://www.gp.com/build/images/icon_pdf.gif
Nautilus™ Wall Sheathing (123KB/1pg)
//Start Ajax tabs script for UL with id=“maintab” Separate multiple ids each with a comma.initializetabcontent(“maintab”)
Marcel:)
