Over-heated Main
Originally Posted By: jpope
Found this on today’s inspection. The 100 amp main breaker was melting as well as the conductor sheathing.
![](upload://j3Ih7uZqFO4GvYcudOQEhDO67ho.jpeg)
![](upload://e6lVMqiQJqyS6HQ6SL5CpRhz6PF.jpeg)
Jeff Pope
JPI Home Inspection Service
(661) 212-0738
Classic loose screw.
How many good electricians have a torque screwdriver?
So that’s what a loose screw looks like. I had no idea of the cause, only that there was a problem.
Jeff Pope
“At JPI, we’ll help you look better”
(661) 212-0738
Originally Posted By: jpeck
Jeff,
See the color of that screw? That's from overheating.
Instead of saying it's a "loose screw", I say 'it's a loose / bad connection.'
PROBABLY caused by a loose screw, however, it could have had the screw over-torqued, driving the screw right through the aluminum - the screw would not be loose, the conductor would be loose. Either way, it is a "bad connection".
Jerry Peck
South Florida
I had already completed the report prior to posting this photo or I may have mentioned that the possible cause was a "bad connection."
Jeff Pope
(661) 212-0738
Originally Posted By: jwortham
I use my laser thermometer to check breaker connections.
You can get evidence of overheating and a loose connection before the insulation begins to melt.
Anything approx. 10% outside an average for all the others is something I wouid want to check further.
