When a panel enclosure is used for a junction box is the enclosure required to be sealed properly. Many times I see a screw inserted at the openable part of the cover and many times there is none and the cover is open. I would think it would be the same requirment for a junction box but just thought I would ask.
I noted the knob & tube, open knock outs and was just asking about the enclosure/covers.
We do see alot of these in our area- especially in those sub-panels located in the basement stairways- 1940’s 50’s bungalows and ranches in Parma, Seven Hills etc. Most AHJ’s accept this practice, though it must be said that is indeed a modification of a listed enclosure. So, a closed minded AHJ might balk. I’ve seen a good number of them with the door screwed shut with a single sheet metal screw with the tip blunted. I think if I would have come across it when I was in code enforcement, I would have asked that the old furnace disconnect be yanked and the conductors incorporated into the larger box.
