Originally Posted By: tallen This post was automatically imported from our archived forum.
I see 8- 120v circuts and only 4 ground wires. It is hard to tell from the pic. are they (ground wires) twisted together and terminated or ? I can’t tell.
– I have put the past behind me,
where , however, it now sits, making rude remarks.
Originally Posted By: jmyers This post was automatically imported from our archived forum.
Hello Will,
I would not doubt what you are saying at all. It looks to me like there are several more neutral wires on the bars then there are grounding wires. Most likely they took the two prong receptacles and replaced them with three prong and left them ungrounded.
I believe I can see a bonding wire with white tape running from the ground bar to the neutral bar. I think that is a ground wire running from the bottom bar but it was difficult tell where it terminates, if indeed it is a grounding wire. If that is the grounding wire, where is the bonding wire?
If you had pulled one of those plates off the open ground receptacles I believe you would have found that the grounding wire was missing.
Originally Posted By: wcampbell This post was automatically imported from our archived forum.
Thanks for the super fast repies guys. I believe that you have iy right Joe, this is an older duplex turned condo.
Mr. Allen, good eyes.
-- This Ole House-Home Inspections
William A. Campbell TREC # 6372
Serving the Texas Coastal Bend
(361) 727-0602 (home)
(361) 727-0055 (office)
(361) 229-4103 (cell)
Originally Posted By: cbuell This post was automatically imported from our archived forum.
Another thing to notice about this panel is that there appears to be romex in conduit, which as far as I know is a no-no. It is possible that wherever all of these lines are junctioned they missed the number of grounds that needed to go back to the panel.
