If those are Zurn fittings there may be an issue…
http://www.lawyersandsettlements.com/articles/10631/zurn-pex-brass-fitting-failures.html
**Zurn Pex Faces Class Action Lawsuits **********
May 17, 2008. By Heidi Turner
[RIGHT][RIGHT]
](http://www.addthis.com/bookmark.php)[/RIGHT][/RIGHT]
St. Paul, MN: Consumers who have Zurn Pex plumbing systems in their homes may discover that the system is not all it was cracked up to be. People have already experienced leaking in their homes that has caused significant water damage. Some lawsuits have already been filed, although as more consumers experience problems with their Zurn Pex plumbing more lawsuits will likely be filed.
One such lawsuit was filed in August 2007. The class action lawsuit, filed by Denise and Terry Cox, alleges that brass plumbing fittings used in their residential plumbing system failed, causing extensive damage to their home. The lawsuit seeks to represent all owners with Zurn Pex plumbing systems that have brass fittings. The plaintiffs are seeking replacement of all Zurn fittings, regardless of whether or not they have already failed.
Meanwhile, a different lawsuit was filed by a man and woman who claim that Zurn Pex plumbing systems caused damage to their home. According to the Bismark Tribune, the plaintiffs are requesting the lawsuit be certified class action. The lawsuit alleges that the Zurn Pex brass fittings failed just months after they were installed, causing extensive damage and resulting in health problems.
Consumers are not just concerned about major flooding in their homes, but also about slow leaks. Brass fittings are often hidden in hard to reach areas, such as in drywall or between floors. In such places, a leak could take a long time to detect, in the meantime causing damage to the walls and floors, allowing mold to develop and causing health problems for residents.
People who have not yet experienced leaks or flooding are also concerned. Because the fittings are so difficult to reach, replacing them can be costly and time-consuming. Furthermore, consumers allege that Zurn, the company that makes the Zurn Pex fittings, is not honoring its warranties, leaving customers to pay for repair and replacement of their fittings.
In many cases, the fittings are failing in a very short time after they were installed. One person who wrote to LawyersandSettlements.com noted that he had fittings fail within six months of being installed, causing flooding in his home.
As more people experience problems with their Zurn Pex plumbing systems, more lawsuits will likely be filed. Consumers are upset that their plumbing systems do not work as well as they should, cause water damage and health problems and require major repair work. Such repair work includes wall, floor and tile repairs, all of which can be expensive and frustrating, especially if the fittings were recently installed.
If you have Zurn Pex plumbing in your home, you may be eligible to join a class action lawsuit against Zurn Industries. Contact a lawyer to discuss your legal options.
