I inspected a home yesturday that the potable water lines were Pex Tubing almost translusent white. But all the fittings looked like the Old Grey Polybutylene Fittings. What type of fittings can be used?
To expand on this they are large grey compression type fittings
A picture would be helpful. Wirsbo brand PEX uses this type of connection ring instead of the metal compression rings. http://www.pexsupply.com/categories.asp?cID=54
Is this what you are talking about?
Not aware of compression fittings of that type for Pex.
Bump.
John Kogel
www.allsafehome.ca
Anyone have an answer for me?
Hi Rick,
I tried to research this for you but can’t find the deffinative answer, but heres my thoughts. All of the PEX manufacturers have very specific installation guides and adherance to those is part of the warranty, all that I have seen have used a metal “barbed” fitting and a special crimp tool to make the joint, I have never seen that fitting used with PEX and believe it to be wrong, but I’d need to know the pipe manufacturer to be 100% sure.
Regards
Gerry
The fittings look like Polypropylene to me.
That is a PB fitting but not one that was included in the settlement fund.
http://www.pbpipe.com/Eligibility/ExcludedSystems/tabid/69/Default.aspx
I don’t think the exact dimensions are the same so that PB fitting should not be used with PEX or at least not considered a PEX plumbing component making it technically wrong.
Here is a picture of a polypropylene fitting:
and another color:
http://www.coleparmer.com/catalog/product_view.asp?sku=3160330
Is it possible it could have been fittings as shown below.
I have seen some similar on jobs and they were Watts fittings.
This is similar.
http://www.ardipex.com/pex-fittings-compression.php
Compression PEX Fitting (PF1)
**PEX **Equal straight union
http://www.ardipex.com/images/pex-fittings/pex-fitting-compression-1.gif
SpecificationsDescriptionPF1-S1216×1216
PF1-S1620×1620Both ends connected to PEX pipes of same size.
E.g.: F1-S1620×1620 means both ends connected to PEX pipes 1620.**PEX **Male union
http://www.ardipex.com/images/pex-fittings/pex-fitting-compression-2.gif
SpecificationsDescriptionPF1-S1216×1/2One end connected to PEX pipes,the other to female threads.
E.g.: F1-S1620×1/2 means one end connected to PEX pipes 1620,the other to 1/2 female threads.**PEX **Female union
http://www.ardipex.com/images/pex-fittings/pex-fitting-compression-3.gif
SpecificationsDescriptionPF1-S1216×1/2F
PF1-S1620×1/2FOne end connected to PEX pipes,the other to male threads.
E.g.: F1-S1620×1/2F means one end connected to PEX pipes 1620, the other to 1/2 male threads.**PEX **Equal elbow
http://www.ardipex.com/images/pex-fittings/pex-fitting-compression-4.gif
SpecificationsDescriptionPF1-L1216×1216
PF1-L1620×1620Both ends connected to PEX pipes of same size.
E.g.: F1-L1620×1620 means both ends connected to PEX pipes 1620.**PEX **Female elbow
http://www.ardipex.com/images/pex-fittings/pex-fitting-compression-5.gif
SpecificationsDescriptionPF1-L1216×1/2F
PF1-L1620×1/2FOne end connected to PEX pipes,the other tomale threads.
E.g.: F1-L1620×1/2 F means one end connected to PEX pipes 1620,the other to 1/2 male threads.**PEX **Wall-plated female elbow
http://www.ardipex.com/images/pex-fittings/pex-fitting-compression-6.gif
SpecificationsDescriptionPF1-L1216×1/2F(Z)IIOne end connected to PEX pipes,the other to 1/2 male threads.
E.g.: F1-L1620×1/2 F(Z) means one end connected to PEX pipes 1620,the other to 1/2 male threads.**PEX **Equal tee
http://www.ardipex.com/images/pex-fittings/pex-fitting-compression-7.gif
SpecificationsDescriptionPF1-T1216×1216×1216Three ends connected to PEX pipes of same size.
E.g.:F1-T1620×1620×1620 means three ends connected to PEX pipes 1620.**PEX **Connector core for manifold
Marcel :)
The Pipe look more like CPVC rather than PEX.
It is marked pex Dale. http://www.astm.org/Standards/F876.htm
Perhaps Flair-It Fittings???
http://store.flairit.com/c-99-flair-it-male-tees.aspx
http://store.flairit.com/c-89-flair-it-couplings.aspx
Hey Guys thanks for the help. I sent your replys to the buyers Realtor to discuss with his client. I still dont have a definite answer but it has to be wrong I think i’ll call the manufacturer of the pipe and E-mail them pics of the fittings.
