Plaster walls and ceilings
Originally Posted By: jfarsetta
negative…
sometimes, plaster was applied over wire mesh in ceilings AND walls. Ceilings are mure common, but I've seen it in walls, as well. With plaster over rock-lath, the actual plaster is only a skim-coat...
Okay … but looking for mesh applied directly to framing without a back-up (lath or whatever)? I have never heard of mesh directly on wood framing without a back-up. Am I missing something here or just misunderstanding Russell’s post?
Robert O’Connor, PE
Eagle Engineering ?
Eagle Eye Inspections ?
NACHI Education Committee
Originally Posted By: gbeaumont
Hi to all
I have to agree with Joe F I’ve seen plaster on both walls and ceilings adhered to the framing with a metal mesh, mostly I’ve seen in on higher end homes build around the turn of the century, and mostly in homes that have ornamental plasterwork and curved walls/ceilings. I just looked unfortunately I do not have a photo on file that shows it.
Regards
Gerry
Gerry Beaumont
e-mail : [email protected]
NACHI phone 484-429-5466
Inspection Depot Education
[email protected]
"Education is a journey, not a destination"
Originally Posted By: nlewis
The plaster walls and ceilings with the wire lathe/mesh are usually in excellent condition compared to the plaster with wood lathe.
When you come across the wire lathe, be careful of the knob and tube wiring; the metal lathe can easily cut through the cloth insulation and come in contact with the live wiring. It happens on rare occasions.
Originally Posted By: jhagarty
Joseph Hagarty
HouseMaster / Main Line, PA
[email protected]
www.householdinspector.com
Phone: 610-399-9864
Fax : 610-399-9865
HouseMaster. Home inspections. Done right.
I think we are on the same page. Plaster will usually not have joints, and drywall will have joints. But joints may not be visible with a good drywall install, or a decent one with a few coats of paint. Also, you may get a shadow effect from rock lath backup joints, but at a closer spacing, or the more recent gypsum veneer panels with thin plaster coat. I think its better to look at penetrations and attics, and tap your fingers on the wall … drywall will be more of a hollow sound.
Very curious now about metal lath without any backup, since I haven?t run across that ? was it common in the northeast? I had thought that some type of backing material over the framing (like building paper more recently?) was applied to limit the amount of plaster used. The following is one of the better links I have on old plaster walls and ceilings.
http://www2.cr.nps.gov/tps/briefs/brief21.htm
But it still refers to building paper or a vapor barrier backup behind the metal lath for replacements. Anyone know of a good link/website that discusses plaster on wire lath without any backing?
Robert O'Connor, PE
Eagle Engineering ?
Originally Posted By: jremas
Let us not forget the remodeled homes that have sheetrock screwed over the top of the plaster & lath or rock lath walls & ceilings. It will sound very solid but it still has both & we may never know it. Joe F is correct when he stated we can only report what we see in a non-invasive inspection.
Jeff Remas
REMAS Inspections, Inc.
Northeastern PA & the Poconos
www.NEPAinspector.com
570-362-1598
Jeff, I agree that only what is seen can be reported. In fact, I think when I’m wearing my HI hat that my job is only to “Observe & Report”.
But, in order to effectively inspect something I think you must be able to identify that material/system and particular issues related to that. Other examples would be composite siding vs. hardboard siding, or EIFS vs. stucco ... huge differences.
Still curious about plaster without backup/backing ... anybody?
Robert O'Connor, PE
Eagle Engineering ?
I have yet to see a sheetrock and paint wall that I can’t tell it’s that with a very bright flashlight shining down the wall.
Sometimes I have to go to the top of the wall or the bottom of the wall to see the joints but I can see them.
That includes some professional level 5 finishes in commercial applications.
I couldn't see them with just the bare eye, but that flashlight shining down the wall, (I use a 1/2 million candlepower) at the top or bottom has always given them away.
Erby Crofutt
B4U Close Home Inspections
Georgetown, Kentucky
www.b4uclose.com
Originally Posted By: dbroad
Its easy to tell. Use a metal detector or a strong magnet on a string or pivot point, if its metal lath the magnet will draw towards the wall every where. icon_biggrin.gif
As I said a metal detector works great. Proof in point, me and the wife are building a new house. I asked the concrete contractor why he didnt put the wire in the breeze way as it called for it, he said he did, he cryed when I grabbed the metal detector from the truck. After I proved him wrong I gave him a choice to eather tear it all out and do it again or pour us a driveway. Me and the wife are injoying our new free driveway.
Robert O'Connor, PE
Eagle Engineering ?
Originally Posted By: phinsperger
dbroad wrote:
Its easy to tell. Use a metal detector or a strong magnet on a string or pivot point, if its metal lath the magnet will draw towards the wall every where. ![icon_biggrin.gif](upload://iKNGSw3qcRIEmXySa8gItY6Gczg.gif)
The magnet type will also work to tell the differance from drywall and wood lathe and plaster. On drywall it will of course pick up the screws or nails at their usual spacings but in wood lath it will either pick up the nails on the lathe which are much closer or if the plaster is thick, it won't pick up anything at all.
The electonitc stud finders can be used to tell the differance because you'll have a much harder if not impossible time using one on a lathe and plaster wall because of the varing density the stud finder picks up. As the plaster oozes though the lathe, it creates a very incosistant depth on the enclosed side of the wall.
Paul Hinsperger
Hinsperger Inspection Services
Chairman - NACHI Awards Committee
Place your Award Nominations
here !
On interior plaster, backing is not used. Hardwall or gypsum plaster is on interior walls. The paper is only used for a water barrier, it isnt needed on the inside.
dbroad wrote:
... The paper is only used for a water barrier, it isnt needed on the inside.
Okay, but isn't it used to also limit the amount of plaster applied? As a former mason (but not a plasterer) I always looked for where it would end with the amount of material you used. Without the backing (building paper, wood lath, or whatever) ... seems like there might be a ton of useless plaster that just pushes through.
I am just not following this metal lath only install for plaster walls ... but maybe that is just the dumb mason in me ... ![icon_lol.gif](upload://zEgbBCXRskkCTwEux7Bi20ZySza.gif)
Robert O'Connor, PE
Eagle Engineering ?
No the paper is not needed. I can plaster a wall without the paper and hardly any plaster falls. You just have to know what you are doing.
When the scratch coat is applied you lay it on the lath, dont push it thruogh. You also need to lath it properly or in the proper direction. If you run your hand up the wall it should be smoother then if you run it down. Or if you get down and look up towards the lath you should not be able to see through it well, as if you look down towards the lath you should be able to see right through it.
