Recently noted defects with a TPR valve on a pre listing inspection. It does not flow with gravity and discharges into a wall/ unknown location. Plumber came out and said that it’s good to go and did not change anything.
The buyers inspector called it out as well and now the sellers are frustrated.
Do you fight with the plumber to make them fix issues or do they override and take responsibility for the defects now?
I pulled to code up and here in FL it is supposed to flow with gravity. I told them that I can’t make anyone fix anything and that the licensed plumber is who to go to. Thank for getting back to me.
Along with what others have said, Explaining the potential implications of a TPR failure might help them make their decision. In Florida (or any where) I’ve found that second, third or fourth opinions often yield very different results.
On a side note, I am curious as to why the plumber said it was ok. If I were the seller, I would pursue this. I suspect it is an older condo, and the AHJ doesn’t require the upgrade because it is not reasonably attainable or cost-efficiently feasible with a simple tank swap.
ndegaris
(Neil DeGaris, CMI® KY License # 102167)
8
I appreciate all of the responses. This was a flipped/renovated home. I do inspections for the investor prior to listing so they can fix things, but it doesn’t appear to be happening.
The plumber provided a video of the discharge location for the owner. I have not seen it.
I don’t fight with anyone over anything. I’m a home inspector, not an interloper. Some overzealous inspectors see themselves mercenaries. Report what you find. What my customers do with the information they hired me for and that I provide is up to them. As home inspectors we have no authority to make anyone do anything.
Did you find a termination point for TPR pipe. Wow what a set up. And NO, we dont tell anyone what to do, we make observations and recommendations and leave it up to the negotiating.
I did not locate it because it enters the wall and I did not open the valve to see where it might be discharging at. I had my assumption of where it was, but it might have been the old condensate line as well. A new HVAC system was installed and a new line was routed right next to the an older line. I believe the plumber did and found where it was going.
I would not have done that either.
Generally, with enough consideration and process of elimination, the discharge point can be identified. Of course, this is more difficult with multi-unit buildings. However, I believe it is crucial because it may help identify a faulty TPRV if it is discharging warm water. (which is one way to separate it from condensate.)
