Plumbing vent caps or Not?
2006 build, two vent’s both had what appeared to have caps. Several houses next to where i was inspecting i could see had these on top as well. Are they caps?
Every drain flow was normal. I am just curious as to what they are for? I’ve seen plumbing test caps left behind before but these appear to part of the CVP pipe.
So you didn’t walk the roof, or use other means, to see the top of the “fixture”?
What’s the top look like?
did you walk the roof? they may have rodent screens on them.
I’m assuming…
No walkie rooftop this morning, so no view of the top of vent.
Thanks JJ for educating me on vents with screens. I have not seen them before.
