Podcast Training For Home Inspectors
First things first. I am a NERD about our profession. After 33 years in this business I decided to read the entire National Home Inspector Exam and make detailed notes about the entire book. I then ran my notes into AI and use the podcast creation tool. I have been listening to these podcasts and I have to say that they are pretty good. My goal in this profession has always been to encourage people to learn more, do more, and increase your value so you can charge more. For those of you having issues with the NHIE; please listen in and I hope it helps.
Are you sure that audio-only is the best medium? My first (overwhelming) thought was that you need diagrams to go with the audio to be effective.
I am sure audio-only is NOT the best. My background does in include adult education. The key to getting information into an adult learner’s long term memory is to as many senses as possible and repetition. What’s nice about a podcast format is that you can listen while you are driving or working out. The more times you hear, see, touch, smell, taste, and any other sense that I am not thinking about will equal the more information that is stored, This is just another tool to help someone learn something that they didn’t know beforehand. In no way is this a substitution.
Season 1 - Electrical Systems :high_voltage:
  1. Electrical Service: Drops, Laterals, Clearances, Ratings, Equipment (27:29)
  2. Grounding and Bonding: Grounding Systems, Bonding Requirements (22:36)
  3. Electrical Enclosure Interiors: OPDs, Fuses, Circuit Breakers (32:00)
  4. Subpanel Grounding and Bonding: Subpanel Configuration, Neutral Isolation (23:19)
  5. Required and Dedicated Branch Circuits: Kitchen Circuits, Bathrooms, Appliances (29:46)
  6. Receptacles, Switches, Lights and Appliances: Types, Locations, Requirements (27:03)
  7. Modern Wiring Methods: NM, AC, MC Cable, Conduit Types (24:50)
  8. Old Wiring Methods: Knob & Tube, Cloth-Covered, Aluminum (34:40)
  9. Basic Electricity and Calculations: Ohm’s Law, Watt’s Law, Joule’s Law (22:44)
  10. Smoke and Carbon Monoxide Alarms: Types, Locations, Service Life (28:28)
  11. Problematic Panelboards: Federal Pacific, Zinsco, Bulldog (25:57)
  12. Alternative Energy and Generators: Solar PV, Wind Turbines, Generators (32:03)
  13. Updating Electrical Systems: Code Compliance and Modernization (28:03)
  14. Glossary of Electrical Terms: Essential Definitions (30:21)
:link: Main Website: nhiexamprep.com
Cool idea!
Season 2 - Cooling Systems :snowflake:
  1. Inspection Scope and Cooling System Terms and Classifications (30:58)
  2. How Air Conditioners Work (33:00)
  3. Determining Air Conditioning System Capacity (26:44)
  4. Inspecting Air Conditioning Systems (38:12)
  5. Related Air Conditioning System Components (27:48)
  6. Air Distribution System Types (25:44)
  7. TYPICAL DEFECTS (31:36)
…Is to tie information into an emotion.
It’s why you can remember every detail of the car crash or near miss you had 30 years ago, but can’t remember what you had for lunch yesterday.
Thank you mark. Strong emotions do go into the long term memory far stronger. Maybe it is better to watch the videos while you are driving. Then every time you get into an accident, you will remember what you were watching.
Hmmmm, there is a lot of info. Not sure how many cars I will need.
I know we don’t know each other that well, I was just trying to crack a little joke.
Just to add to what you said; that is also why we remember things that piss us off as well. The problem with our profession is that all of the stuff we need to put in our heads is not all that emotional to us. So using other senses does help.
Is this all AI podcast ?
These are. Yes. I will be uploading my videos as well. Just trying to help.
Season 3 - Heating Systems :fire:
  1. Fundamentals & General Inspection (37:10)
  2. Gas Appliances & Categories (31:21)
  3. Gas Forced-Air & Specialty Furnaces (37:49)
  4. Gas & Oil Venting Systems (25:07)
  5. Electric Heating Systems (30:05)
  6. Hydronic Systems (41:42)
  7. Additional Systems & Components (29:35)
Season 4 - Plumbing Systems :potable_water:
  1. Introduction and Scope - House Plumbing System Overview (24:38)
  2. Plumbing System Terms - Essential Vocabulary for Home Inspectors (24:17)
  3. Water Service and Distribution Pipes - Materials, Installation, and Common Issues (30:25)
  4. Water Connectors, Valves, and Backflow Prevention - Critical Safety Components (31:00)
  5. Wells and Fire Suppression Systems - Private Water Supply and Safety Systems (34:17)
  6. Domestic Hot Water Systems - Storage Tank and Tankless Water Heaters (33:38)
  7. Drain, Waste, and Vent Pipes - DWV System Materials and Installation (41:11)
  8. DWV System Components - Fittings, Cleanouts, and Flow Direction (28:10)
  9. Plumbing Vents - Protecting Trap Seals and System Function (34:15)
  10. Plumbing Fixtures: Faucets and Sinks - Operation, Installation, and Common Problems (37:35)
  11. Plumbing Fixtures: Bathtubs and Showers - Installation Requirements and Leak Prevention (30:34)
  12. Plumbing Fixtures: Toilets and Other Fixtures - Function, Components, and Common Issues (24:23)
  13. Sewage Ejectors and Sump Pumps - Pumping Systems for Below-Grade Fixtures (31:37)
  14. Fuel Storage and Distribution Systems - Gas and Oil Systems for Home Inspectors (43:34)
  15. Private Sewage Disposal Systems - Septic Systems and Home Inspector Responsibilities (39:03)
Season 5 - Fireplaces & Chimneys :fire:
  1. Inspection Scope and Terminology (29:53)
  2. MASONRY FIREPLACE COMPONENTS AND CLEARANCES (29:21)
  3. FIREPLACE OPERATING EFFECTIVENESS (36:32)
  4. MASONRY CHIMNEY CONSTRUCTION (48:00)
  5. FACTORY-BUILT FIREPLACES AND CHIMNEYS (33:47)
  6. GENERAL CHIMNEY ISSUES (11:17)
  7. FIREPLACE INSERTS AND WOOD-BURNING STOVES (23:17)
  8. CLEARANCE TO COMBUSTIBLES REDUCTION (28:15)
Season 6 - Kitchen Appliances :cooking:
  1. INSPECTION SCOPE and APPLIANCE TERMS (31:50)
  2. COOKTOP, RANGE, OVEN (29:00)
  3. DISHWASHING MACHINE (36:02)
  4. MICROWAVE OVEN & EXHAUST HOOD (27:32)
  5. FOOD-WASTE DISPOSER (31:36)
  6. TRASH COMPACTOR (31:08)
  7. REFRIGERATORS & FREEZERS (23:57)
Season 7 - Site Conditions :house_with_garden:
  1. INSPECTION SCOPE AND TERMINOLOGY
  2. RETAINING WALLS
  3. GRADE AND DRAINAGE
  4. Vegetation
  5. DRIVEWAYS, WALKWAYS, AND PATIOS
  6. POOL AND SPA ACCESS BARRIERS
Season 8 - Exteriors :house:
  1. INSPECTION SCOPE AND TERMINOLOGY (35:16)
  2. EXTERIOR WALL COVERINGS AND TRIM (44:06)
  3. FLASHING, SEALANTS, AND EAVES (24:23)
  4. EXTERIOR DOORS (33:25)
  5. EXTERIOR WINDOWS (32:51)
  6. STOOPS AND PORCHES (34:46)
  7. BALCONIES (31:54)
  8. DECKS (PART 1) (28:3)
  9. DECKS (PART 2) (38:33)
  10. DECKS (PART 3) AND GARAGE DOORS (38:57)
Season 9 - Roof Components :house_with_garden:
  1. Steep Slope Roof Coverings (PART 1) (36:05)
  2. Steep Slope Roof Coverings (Part 2) - FIBER CEMENT (37:04)
  3. Steep Slope Roof Coverings (Part 3) - Metal Roofing (39:33)
  4. Steep Slope Roof Coverings (Part 4) - Slate, Wood & Ice Dams (36:15)
  5. LOW SLOPE ROOF COVERINGS (PART 1) (34:50)
  6. LOW SLOPE ROOF COVERINGS (PART 2) (28:38)
  7. ROOF DRAINAGE SYSTEMS (24:45)
  8. ROOF FLASHING (34:58)
  9. SKYLIGHTS (31:53)
Season 10 - Structural Components :house_with_garden:
  1. Inspection Scope and Terminology (31:55)
  2. Foundation Systems and Forces (31:00)
  3. Basement and Crawl Space Foundations (37:32)
  4. Slab Foundation Systems (36:58)
  5. Floor System Components (28:47)
  6. Wall System Components and Materials (48:27)
  7. Fireblocking, Fire Separation, and Foam Materials (39:04)
  8. Roof and Ceiling Systems (42:47)
Season 11 - Insulation and Ventilation :house_with_garden:
Inspection Scope (25:55)
Introduction to Insulation and Ventilation (28:30)
Insulation and Ventilation Terms (32:32)
How Insulation Works (22:58)
How Vapor Retarders Work (34:50)
The House as a System (36:14)
Common Types of Insulation (36:14)
Energy Efficiency and Moisture Management Components (39:57)
Mechanical Ventilation and Exhaust (37:48)
Attic Ventilation (43:20)
Crawl Space Ventilation (31:23)
Season 12 - The House Interior :house_with_garden:
Interior Wall and Ceiling Finishes (35:26)
Interior Doors (36:05)
Floor Coverings (41:18)
Stairways and Landings (37:02)
Cabinets and Countertops (36:50)
Smart Home Technology (13:12)
