Looks Like Polybutylene pipe?
Until I google the standard stamped on the pipe, Conforms to ASTM F876/F877 which only refers to Pex pipe. I plan on identifying this as PEX
PB 2110 is the most common marking used to identify polybutylene pipe.
More info:
Thanks Larry, I agree. The only readable portion on this pipe was the ASTM standard numbers
Based upon the available information, I would classify it as “PEX-B.”
Looks like PEX tube
Looks like PEX from here. PEX the new Poly. ![]()
This is PEX-A pipe, it’s the only PEX that comes in clear. It is usually used with expansion fittings, but works just fine with crimp fittings also.
Pex-B Is solid in color and can’t be expanded.
There is nothing called PEX #2 pipe.
If you would have looked closer at the printing it would say in the pipe.
ICBO E8 is a reference to a section within the International Plumbing Code (IPC) related to piping, and F876 is an ASTM standard for crosslinked polyethylene (PEX) tubing.
