Aside from CPVC being a less flexible pipe with a shorter warranty than PEX, it’s still appears to be a material that’s permitted by code for use in residential dwellings. Correct me if I’m wrong.
My question is, what are you going to put in your reports about CPVC other than a link to an article or news story? Seems like there’s some anecdotal evidence of it failing and causing leaks, but who is proving that the failures are happening within the warranty period, or caused by conditions other than improper installation?
I note that it has been known to have a higher failure rate than other allowable materials. Improper installation would be a completely different narrative. CPVC is just brittle in general. Like I noted above, it is very rare to see around here.
The most experience I have with CPVC is when it was used as part of the condensate drains on the Lennox Pulse furnace. The company I worked for at the time of the Pulse recall was a Lennox dealer. We did a ton of change outs. You barely pulled on it, and it would snap.
Unlike other materials that have some give, you bump into or snag CPVC while working in the basement or crawlspace there is a fairly good chance that you could have failure.
Yes. Polybutylene.
Plastic potable plumbing pipes with “PB2110” stamped on them are polybutylene pipes. InspectApedia
The upper pipe is ASTM D2846. Refers to a standard for Chlorinated Polyvinyl Chloride (CPVC)plastic pipes and fittings used for hot and cold water distribution systems.
Just wondering. Was that image taken in the laundry room, near the washing machine standpipe?
The image shows two different colored plastic domestic potable water supply pipes. The lower plastic piping could be some replaced piping that was installed after a leak is what I am alluding to.
Request full disclosure from the vender or venders agent. Was the home ever flooded? Where domestic plumbing water supply pipes ever repaired and if so why?
Not a damn thing, unless there’s a problem or condition that needs to be reported.
There are about a billion miles of CPVC installed down here, and yes, it has problems in attics (but not always) or high heat (at what temperature is yet to be defined).
In Florida, Copper isn’t used due to pin-hole leaks, so CPVC or PEX are the only real remaining choices. So, what’s the next plumbing pipe supposed to made out of?
Most common issues I see with PEX is from DIY and Flippers installing it in basements exposed to direct UV/ sunlight through the basement windows, causing…
Thank you, Jeff. Do you recommend that a qualified contractor evaluate the CPVC and repair or replace as necessary and according to modern building standards?
(As Jeff stated)… Like with Electricians and FPE/Zinsco Panels… Replace is about the only recommendation a typical Plumber will suggest for CPVC plumbing materials.
