Looking for y’all’s opinion here - I just had a request to do a pool inspection with a home inspection I have scheduled for next Friday. Is that enough time to go through the course and become competent enough to let them know I can do that?
I don’t want to turn down the money but at the same time I want to make sure I am providing a good service. I know this is a pretty trivial question but just wanted a quick answer from those who have experience with pool inspections before I agree to take it on.
Take the course today then make your decision for yourself. Knowing your limitations, and the limitations of ANY area of inspection, can only make you better. I rarely see pools (we love our lakes in Minnesota) so I’m not gonna waste a lot of time on training. I will do a basic conditional inspection WITHOUT testing of pumps/filters/etc. and refer those to a Pool Expert.
I’m sure between the course and any tips from knowledgeable inspectors here, you will be competent enough to provide the service.
Note: be sure to get the inspection limitations into your Agreement so you are covered ‘legally’!!
To those naysayers about deferring the entire inspection to an “Expert”…
Salt water pool two years ago. They called an ‘Expert’ so I didn’t have to even look at it. As a Professional Inspector, I did what I do anyway. My client and the agent called me after reading my report to ask me about a couple of ‘issues’ I mentioned in my report that the ‘Expert’ did not and had no clue when queried!!
Always provide your best, whether you need to or not. You never know who the guy behind you will be!!
Love it! Thanks Jeffrey, exactly what I was looking for. I don’t imagine I will get too many of them but nice to have an add-on to offer since radon testing is pretty much non-existent in my area.
Please be sure to check the electrical well.
Motor/pump bonded? Equipt & light breakers on GFCI circuit?
Light (if any) on a high voltage transformer?
How about drainage away from the pool structure.
I have been doing swimming pool inspections for 12 years and have been cleaning and maintaining pools for more than 30 years. While most things on a pool is straight forward, there is a lot of liability to consider when inspecting a pool. I just finished a home inspection of 11,000 sq ft home and the pool was still more of a challenge than the home.
A lot of the swimming pool technology is specialized and requires some experience just to operate. Salt water pools and chlorine generators are something that is not covered in detail in most pool inspection courses.
The thing you should pay close attention to is the liner. Whether plaster, vinyl or exposed aggregate, the liner has the most liability. Pay close attention to crack, stains, chips, and calcium etching. Note everything you see.
All good stuff to know here, I appreciate everything that’s been shared. Definitely will make sure I feel comfortable and confident before showing up on site!
I think the inspector called the motor not grounded/bonded.
The electrician fixed it (NOT)
The reinspection said it was OK.
Also the pool light did not have a high voltage transformer, no one called it.
