Master Bedroom door leading outside with signs of water
intrusion…Southern calif. not too much rain. Thinking it may
be sprinklers pointing back at the house ? The house is 4 yrs old
empty foreclosure…
First picture looks like a replacement sweep was installed. Does the door still have the original sweep that comes installed under the door panel. This may be an issue.
Do you have a picture of the top of the door? I will bet wood casing abuts the stucco without proper flashing and/or sealant. The wood side jambs abut stucco and are not sealed. You can see light in picture number 2 where the weather strip is incomplete.
