Master certification class homework, exterior, front door.
Upon inspection of the front door, I observed, at the bottom of the trim where the trim meets the ground, there is evidence of water intrusion and a general lack of maintenance. If not addressed this could lead to a more serious water intrusion situation. Evaluation and correction by qualified handyman or professional is recommended.
Main entry door has some deterioration at bottom of door jamb/trim both sides. Further deterioration or leaking may occur if not corrected. Recommend repair by qualified contractor.
Such a great point. When I am in a crawl or basement, I pay special attention under doors and deck attachment. And, I tend to find termites around the rim joist that abuts to the garage and the front stoop.
