power cord for range through floor
Twice in last 2 inspections I find the power cord for the electric range passes through the floor into the basement below where it plugged into the expected receptacle. I believe disconnection means must be in same room as appliance, and visible (behind removable bottom drawer OK). Otherwise a second means of disconnect must be provided. QUESTION? Am I correct in my thinking?
Thank you in advance.
To meet the requirement of a disconnecting means the cord and plug must terminate in the space behind the drawer and also the cord cannot pass through the floor. A few NEC sections:
Thank you Robert for your fast answer; most appreciated
