pressure treated wood
Originally Posted By: mcyr
Hi. everyone;
Just a short note to all HI's out there that I have received a bulletin from Simpson Strong Tie Company, that explains the corrosive affect on their product since the pressure treatment was changed a few years ago to eliminate the arsenic in the wood. It appears that the new process of pressure treatment, has caused the strong ties connectors to corrode at the rate of two and one half times faster than the projected life of the connectors.
More information can be obtained by viewing the article.
www.stongtie.com
Hope this helps, cause now we have something else to inspect.
Marcel
Originally Posted By: jschwartz1
Thanks Marcel. This was posyed a while back but is always a good refresher.
CCA vs ACQ
ACQ will make a tapcon turn orange in less than 30 days.
Really nasty chemical, but the EPA wants it.
Jay Schwartz
Coast To Coast Home Services, Inc
www.Coasttocoasthomeservices.com
Southeast Florida NACHI Chapter - VP www.floridanachi.org
NACHI - Legislative Committee Member
MAB - Member
For newer treated wood installations (likely ACQ treated lumber), look at the fasteners closely … should be stainless steel or heavy coat hot-dip galvanized fasteners.
Here is a more general reference that includes a link to that Technical Bulletin ... http://www.strongtie.com/productuse/corrosion.html?source=hpnav
Here is also a link to the types of fasteners recommended with ACQ lumber for the various fastener manufacturer's ... http://www.treatedwood.com/fastener.pdf
Robert O'Connor, PE
Eagle Engineering ?
Eagle Eye Inspections ?
NACHI Education Committee
Originally Posted By: hspinnler
http://www.nachi.org/bbsystem/usrimages/1/100_52282.JPG
Nice to see that, considering Maine is ten years behind everyone else, that some of you inspectors are on top of it.
Who knows what the future will bring with all these new products!
Marcel
That’s right. I have not looked into it yet, but I am interesed in knowing how much of the market the new paperless drywall from Georgia Pacific will own. They are advertising it heavily here in Georgia. Website is www.stopfeedingmold.com
Have a happy Fourth of July.
Hank
Have you seen this product in the field yet?
I haven't.
Working in Portland, Maine tomorrow and will stop by KAMCO who is a distributor of this product. Will try to get some feed back on performance if available.
Marcel
Originally Posted By: dedwards
There have been numerous articles and other general information in the JLC magazine about the problems with the newer pressure treated lumber.
I heard recently,from a local Architect that there is already a new recipe if you would call it, to the pressure treatment formula to address this problem.
Has anyone heard anything about that?
Thanks
Marcel
Originally Posted By: lewens
Marcel
I have been all over the web trying to put together a paper on PWF and have not found anything on a new formula. Could you ask the architect for a reference I am very interested?
Larry
Just my usual 12.5 cents
From The Great White North Eh?
NACHI-CAN
www.aciss-brant.com
www.certifiedadulttrainingservices.com/
Larry, as soon as I see the Architect again I will ask him, and what ever I found out, I will respond.
The Architect is the the designer of my bosses house that I am building right now. Construction cost without the 42 acres is about $1.5 to 2 million . I guess now I know who is making the money. ha. ha…
Marcel
Originally Posted By: jbushart
Has anyone run across this new treated wood, yet?
http://www.timbersil.com/
Home Inspection Services of Missouri
www.missourihomeinspection.com
"We're NACHI. Get over it."
www.monachi.org
Originally Posted By: jhagarty
http://www.timbersil.com/authorized-treaters.html
NO.
Not Yet.
In this Geographic area, there are Home Builders using Tim-Bor and Boracare Treatments on New Homes as a Preventative method for WDI as well as future Mold Concerns.
http://www.nisuscorp.com/timbor.html
http://www.nisuscorp.com/boracare.html
Product has a demonstrative efficacy on prevention of Mold as well as WDI concerns.
Joseph Hagarty
HouseMaster / Main Line, PA
joseph.hagarty@housemaster.com
www.householdinspector.com
Phone: 610-399-9864
Fax : 610-399-9865
HouseMaster. Home inspections. Done right.
Hi. all;
I have found this info on pressure treatments for wood.
Click HERE to visit our LINKS Page
(Please check out the "IMPORTANT INFORMATION ABOUT CORROSION" Box)
Click HERE to visit our NEWS Page.
BORATE PRESSURE TREATED WOOD
with ENVIROSAFE PLUS?, a proprietary polymer binder,
that provides added protection against exposure to
exterior weather conditions during construction periods.
Product Features
Lumber and Plywood are pressure treated with
Disodium Octaborate Tetrahydrate (DOT) and EnviroSafe Plus?.
For applications in accordance with
AWPA C2 (C31), C9 and building codes per ICC-AC62.
Virtually non-corrosive ? standard G60 and G90 fasteners recommended.
Low toxicity ? low risk to humans and other non-target animals.
Odorless and non-volatile ? no negative effects on indoor air quality.
Effective against termites (including Formosan), carpenter ants,
carpenter beetles, silver fish, fleas, cockroaches
and other household pests.
No color additives ? wood retains natural color characteristics.
Minimum wear on tools.
Low shipping costs ? only 600 pounds per 1,000 board feet added weight.
No adverse effects on strength or elasticity of lumber.
Low weight to strength ratio provides for easy handling.
40 Year Transferrable Warranty.
Product Applications
Fences ? Framing Lumber ? Studs ? Sill Plates ? Floor Joists
Roof Rafters ? Trusses ? Plywood ? Interior Sheathing
Furring Strips ? Pre-Fab Wall Systems ? Moldings
Wood Trim ? Flooring ? Roofing
Derreck Manteau
Tel (Cell): (407) 687-1541 Field Manager
Barry Taylor
Tel (Cell): (407) 448-6600
Area Manager
FL, GA
Jack Rombough
Toll Free: (800) 345-8102 General Manager
VISIT OUR WEBSITE Authorized Treaters Benefits Company Information
Contacts Legal Notice LINKS
News Product Literature Technical Data
Wood Treatment Products, Inc.
P.O. Box 950445
Lake Mary, FL 32795-0445
Toll Free: (800) 345-8102 ? Tel: (407) 330-0177 ? Fax: (407) 330-3243
197 Meadow Beauty Terrace ? Sanford, FL 32771-6481
This page updated on August 7, 2005
Have you guys come across this product yet?
Hope this leads to a building solution to the corrosive affect of the current product.
Thanks;
Marcel
Hi guys
From what I have been able to glean from the web Borate treated wood can only be used above ground and is not to be used in soil contact. So it appears we are back to acq as the alternative to cca. CCA is turning out to be another boondogle on par with asbestos and lead paint. I bet before long we will have cca abatement “specialists” out there charging outragious fees to take the stuff down and dispose of it. Any takers?
Larry
NACHI-CAN
www.aciss-brant.com
Hey Larry, you might be on to something here.
Figure out a way to solve the problem with all the outstanding issues with corrision of existing joist hangers that have been intalled in the past decade, and we might hit it rich.
Now that the problem has been advertized on the table for everyone to see, I would think that someone would have concluded a way to protect previous installations. Dosen't this sound like asbestos?
Maybe this will open up another trade that pays more than HI. business.
Corrosion mitigation Contractor available for your expert resolve on corroding joist hangers. Ha Ha..
Marcel
Marcel
It is just a matter of time
Larry
NACHI-CAN
www.aciss-brant.com
Originally Posted By: Thomas Gaffney
This might be considered slander if it weren’t so well documented and proven in court (you really don’t have a leg to stand on Derreck). If you’d like to know how this guy went out of his way to scam senior citizens in Phoenix just visit the links below… or Google him yourself. He was one of two major partners who knowingly marketed illegal investment “opportunities” in Senior World and the Arizona Republic. I can’t understand why any company would hire such a shameless thief as a manager… :shock:
http://www.ccsd.cc.state.az.us/hot_topics/anmp/pdf/AFFIDAVIT%20OF%20WALKER.pdf
http://www.ccsd.cc.state.az.us/hot_topics/anmp/pdf/Verified%20Complaint.pdf
Originally Posted By: phinsperger
Paul Hinsperger
Hinsperger Inspection Services
Chairman - NACHI Awards Committee
Place your Award Nominations
here !
Originally Posted By: rwand1
This site maybe of interest.
http://www.buildingpreservation.com/Contents.htm
Raymond Wand
Alton, ON
Raymond Wand
Alton, ON
The value of experience is not in seeing much,
but in seeing wisely. - Sir William Osler 1905
NACHI Member
Registered Home Inspector (OAHI)
http://www.raymondwand.ca
