Problems with Sporecyte
I’ve read a post here which spoke positively of Sporecyte. I’ve worked with them and have had mixed results at best.
The first samples I sent them, I was told that one sample was crushed in the mail. I spoke with my customer who wasn’t happy. I wound up returning his money. I dont see how one-handed plastic mold sample cassette was crushed and the other wasn’t, but I gave Sporecyte the benefit of the doubt.
The next 2 sample sets I sent were fine. But after that, I sent two samples for two different homes. Sporecyte only sent results for one set of samples. I had to call them to find out what the problem was, they later provided the results from the second samples.
Thursday I took a surface sample and an air sample. I called to confirm they could take the surface sample, they said yes. After sending in the surface sample and the air cassette. They returned results only from the surface sample. The results only said hyphen, and nothing else. Not the species or anything else. They also, did not send results of the air sample. I am currently dealing with them to either get my results or get my money back.
My question is this: has anyone else had these problems with Sporecyte?
Sending in one air sample is no good, you must send in an exterior control sample as well. Without a control sample that have nothing to compare it with, results will not be accurate.
Always do one exterior control and 2 interior air samples, and any surface swabs. But always 3 air samples.
I know you are trying to save a few bucks, but only doing one air and one surface sample, I wouldn’t accept those tests if it was my lab. You are doing your clients injustice by testing like this.
And btw, maybe ship your samples in a bubble envelope and tell the shopper to put a fragile sticker on it.
I have never had issues with shipping with UPS, only FedEx, they tend to not give a crap. And only ship next day, never 2 day. That’s when things get broken.
The surface sample was the test sample. The air sample was the control sample. When I ship to Sporecyte, I have only ever used the overnight shipping bag that they provide.
We wrap all samples in a sheet of bubble wrap. We have not had any issues.
That’s not how it works, a control air sample needs an interior air samples or 2 to compare it with. A air control sample can not be a control for a surface sample.
I really think you need to take a few more mold courses and stop testing till you do.
If you take a surface sample of visible fungus then it tests for the type, that’s it. It has nothing to do with anything in the air.
You need to take 3 air samples minimum and really no need to swab anything, because if you can see it, obviously there is an issue. No need to know the exact type.
Airborne mold is the issue with the health and well-being of the occupants, unless they are licking the moldy surface.
There may be minimal mold in the air, so just cleaning hard surfaces is needed or removal of drywall.
Just think about it, you do a exterior air sample and interior surfaces sample, how are these 2 things even related to each other?
You are saving $40.00 not doing 2 interior samples, but this passes to the client. You need to charge at least $350.00 for mold testing minimum for 3 air tests And then $50.00 for each other including swabs, tape, etc.
The results will be accurate, you just won’t have any idea if they mean anything.
I had a broken slide on one a couple of weeks ago. I thought the bags were always a little sketchy and the broken slide proved it. The frustration was a bit high at that point.
UPS has the mini boxes that you can order by the case and then use the pre-printed labels from Sporecyte. They work a lot better.
Do you put your cassettes in zip-locks? The reason I ask, my lab recommends samples be in zip-locks, because if the cassette is damaged, they say they may still be able to recover the slide and do the analysis.
Edit, just realized you are talking about a glass slide probably, not the slide inside a cassette.
I haven’t been, but it makes perfect sense.
I notice no one gave you a direct answer to your question. I think it was “ has anyone had a problem with Sporecyte”? I cant answer that because I dont deal cheap. I work with emsl. Good luck.
Morning, Ivan. Hope to find you well.
Never heard of, Sporecyte. BUT!!!
I mostly lived by the principle of vender satisfaction as…Fool me once shame on you. Fool me twice shame on me.
In your case I feel you have given Sporecyte plenty of leeway for current customer satisfaction. I have had new or repeat venders give me sharp discounts to free products.
Customer satisfaction is imperative. Especially when Sporecyte is being courted by a new client.
A poor review left by a client concerning mold sample and report turnaround times or poor to limited sample results could cost you dearly.
Conscientious home inspectors work hard for their money and even harder to maintain one’s quality reputation.
I would have moved on after the second incident; Fool me once shame on you. Fool me twice shame on me.
Wishing you much success with all your endeavors.
I agree with Ryan.. Move on
I appreciate your direct comment and answer to the question. I also appreciate that you dont deal in cheap inspections. Please explain emsl, tell us about them.
If there is a better service provider, I dont mind switching.
https://laboratorytesting.com/
Here is website or you can google it.
Will
All my dealings with Sporecyte have been positive so far.
Are you inferring it could be an issue with the methodology the inspector uses?
EMSL is a good lab, but like everyone else, they have issues from time to time. We used EMSL for many years and switched to Sporecyte mostly because of their reports. EMSL reports are not consumer or layperson-friendly. The Sporecyte reports are easy to read and understand, and we do not get clients calling us wanting us to explain and interpret the report! This has been huge for us!
Whoever you use, take an outdoor control sample and an indoor air sample at a minimum! We take no less than 3 air samples in a home in my company.
Larry gave you a bigger link for emsl. A little more expensive for us in California but is thorough.
100% agree.
