Will this be a problem? The gas stub out is about 3.5 feet from slider window on the right.
Here ya go:
When installed, the regulator (and its safety vent) will be less than 5 feet to a building opening. It needs to be moved. The local LPG supplier can verify this.
The regulator vent termination needs to have the clearance, not the regulator itself. An extension can be added to the vent orifice on the regulator and terminated at the appropriate distance.
