Originally Posted By: Steve Costa This post was automatically imported from our archived forum.
Pete, I think everything would be about the same as natural gas except for the supply lines. We had propane heat years ago before gas came down the street and basically all we had to do to convert over besides running a gas line from the street was change a fitting in the Gas Valve, I believe it was a metering device. Hope this helped, Steve
Originally Posted By: kmcmahon This post was automatically imported from our archived forum.
Yep…see them all the time here…you also should probably add a once over of the tank as well, although around here the gas compainies are good about changing them out if they are deteriorated.
