PVC vent for 90% eff. furnace
Originally Posted By: bking
Does the PVC vent pipe need to be topped off with a rain cover ? Looks like some water can get into the furnace with these PVC flue pipes that vent straight through the roof…
www.BAKingHomeInspections.com
Originally Posted By: dandersen
The vent should slope back to the furnace to be handled by the drain or condensate pump.
All kinds of water condenses inside the vent. A little rain wont hurt.
Got a pic?
no pic, it is a simple straight pipe out of the top of the unit. The unit is installed horz. on its side. A goodman unit
You may have a problem because it is a “Goodman” but not because of rain water.
Originally Posted By: rray
Do you simply not like Goodman, or are you thinking about the recall on horizontal furnaces in California in 2001?
Home inspections. . . .
One home at a time.
Originally Posted By: mgault
Manufactured in: U.S.A.
Remedy: Free thermal safety limit switch. Commercial and institutional owners will install the replacement switch themselves. Individual homeowners can get a free repair. Contact the Goodman Hotline to receive the free replacement thermal safety switch. Inspect and clean the air conditioner/heat pump filters immediately to remove any imminent hazard. Continue to clean these filters every 30 days in accordance with manufacturer's recommendations which can be found at www.regcen.com/PTAC
Owner Contact: Call the Goodman Hotline at (800) 729-6122 between 7 a.m. and 6 p.m. CT Monday through Friday. Owners can submit a PTAC Recall Information Form at Goodman's Web site www.regcen.com/PTAC
To view this recall online, use the following link: http://www.cpsc.gov/cpscpub/prerel/prhtml04/04229.html
Goodman's Hotline: (800) 729-6122
CPSC Consumer Hotline: (800) 638-2772
CPSC Media Contact: (301) 504-7908
Goodman Media Contact: (713) 861-2500 x439
Trane Media Contact: (732) 980-6048
A more current recall...
-Mike
A to Z Home Inspections, LLC
www.atozhomeinspections.net
So nothing out of the ordinary, then, since that 2004 recall (which I knew about) is not on horizontal furnaces (which the 2001 recall is).
For those of you doing recall research, make sure you are talking about the correct appliance type. Otherwise, you'll unnecessarily alarm everyone and look foolish after all the facts are in.
I had a Client a couple of months ago who thought my recall research was the best. Then she moved in and had her house-warming party. Mom got all upset because she remembered that General Electric had issued a recall on kitchen ranges in late 2004. Client called me, and as we were on the phone, I double-checked. Yes, GE did issue a recall in August 2004, but it was for electric coil ranges. Her range was a gas range. She was happy again. End of story.
One home at a time.
Sounds like you’re most likely to run across them in an Apartment converted to a Condo… very popular here in Charleston right now…
-Mike
