I think of them as Powdered Wood Foundations and disclaim them. Only seen two, both bad and I don’t trust them. Proper inspection requires probing through the ground around the foundation with a 6’ metal rod. My understanding is that they can last a while, maybe 30 years, if built correctly, but that’s a big IF and failure to build correctly turns one of the major structural components of a building to mush in not much time. They’re the Yugo of foundations in my opinion.
About 80% of the homes here have wood Foundations here. I have built hundreds myself. Poly on the exterior is not required as long as there is a moisture barrier of some sorts. We use a waterproof bitumen here. Tar all of the nails and joists first and then two to three coats of the bitumen. We do not use The grade level plywood strip as the engineers do not require it here. I know that PWF foundations get a bad wrap most of the time but I can honestly say I see more issues with concrete then PWF.
Only good location for a PWF is on the top of the hill. However if done correctly in the right location it will give less trouble than some concrete foundations.
Required by the engineer or not, missing grade level protection is always called out in my reports. It is (supposed to be) there for a reason! Whenever I see the protection is missing, 9 out of 10 times there is damage from lawn mowers and weed whackers!
I would be calling up every home I inspected if I called up the grade level protection. The parging is there to protect it. That is mandatory in our area as the UV light can break down the plywood fairly quickly.
Not as many as you but I have seen them sink crack lift on clay soil. Unfortunately here in SSM clay is everywhere. I would not use any PWF that might get wet for a period of time during flood season. Also Parging or Damp proofing is very minimum protection in my mind and will not stop water like a cement foundation will with proper draining and foundation dimpled protection. http://www.supersealonline.us/categories/Dimpled-Foundation-Membrane-%26-Accessories/
Thanks for the info Gregg. I heard about PWF 35 years ago, believe it or not. But never seen one.
At the time it had already been proven to sustain for years to come.
Wish I could see one that was built way back.
