QOD for 1/26/04
Originally Posted By: dbush
Here we go.
Dave Bush
MAB Member
"LIFE'S TOUGH, WEAR A HELMET"
Originally Posted By: phinsperger
Dave,
QOD, A great idea. I love it.
Paul Hinsperger
Hinsperger Inspection Services
Chairman - NACHI Awards Committee
Place your Award Nominations
here !
Originally Posted By: gsutterfield
Dave
Gotta say A .60 . Don't think the trailers at the local trailer park could handle even that much as the city has had to install regulators ![icon_wink.gif](upload://ssT9V5t45yjlgXqiFRXL04eXtqw.gif)
Answer for this question is B: 80 psi. Some study/reference material say 75 - 80, but 80 is generally the “watch” point for psi of water pressure.
Dave Bush
MAB Member
Originally Posted By: rking
Measure water pressure???
You have to be kidding!
Is there any inspector that goes that far beyond the standards?
Muskoka Home Inspections
“Wisdom is the Anticipation of the Consequences”
Steering Committee Member At Large
Originally Posted By: Blaine Wiley
I check static water pressure and functional flow on every inspection. It is simple, no different than putting an outlet tester in an outlet, and gives an idea about how the water flow should be.
Robert, I check water pressure on every inspection. We have several private wells/pumps that the pressure switch is going bad and will get upwards of 90 psi, bad for pipes.
Dave Bush
MAB Member
Originally Posted By: jfarsetta
I test pressure and flow where a private well is involved. For municipal water supply, I open the kitchen faucet, turn on the tub, and flush a toilet.
Joe Farsetta
Illigitimi Non Carborundum
"Dont let the bastards grind you down..."
Joe,
Do you have PRV's on the incoming city water lines? We do here in some areas, and I've caught a couple where they failed or weren't adjusted correctly and the pressure was over 100 psi. (sched. 40 plumbing, too) In VA that used to happen weekly. Anyway, thats why I started checking pressure even on city water way back when.
Originally Posted By: rray
I just found the QODs and am reading through them. My employees and I keep a running record of certain things after each inspection, one of which is the highest and lowest water pressure that we’ve ever found. The highest was 184 psi. Not coincidentally, the seller had disclosed that he had had a lot of problems with leaking faucets, pipe connections, etc. Well, duh! I really have to wonder if he ever used a plumber to repair things. Surely the plumber would have checked the water pressure, if not at the first visit, surely after the umpteenth visit.
![icon_twisted.gif](upload://xjO326gspdTNE5QS3UTl0a0Rtvy.gif)
Home inspections. . . .
One home at a time.
Originally Posted By: pdacey
184 psi !?!?!?!?!? I’m surprised he had any skin left after taking a shower.
Slainte!
Patrick Dacey
[email protected]
TREC # 6636
www.southwestinspections.com
