Originally Posted By: jmyers This post was automatically imported from our archived forum.
As not to give the answer away I will reserve my comments on this question until tomorrow but be warned that is incorrect, even though it was the correct answer you were looking for.
dvalley wrote:
With a three light tester. One light verses two.
Do not trust a 3-light, or any tester, for something like that ... use you senses (yes, the eyes) ...
tallen wrote:
The Panel
Bingo ...  ... that, and removing a few receptacle covers.
I have some very good links/info on GFCI testing ... if it becomes an issue.
-- Robert O'Connor, PE
Eagle Engineering ?
Eagle Eye Inspections ?
NACHI Education Committee
Originally Posted By: evandeven This post was automatically imported from our archived forum.
Here is what I see:
A) Acceptable. Per code, if this is an older home and a true two wire system with no ground, the only way to have a three prong outlet would be to use a G.F.I. outlet and label it ungrounded. As it meets code, which is a safety code, it cannot, by definition, be unsafe.
I answered A for that reason.
B) Safety hazard. See above, unless, the home was a two wire system and was rewired using Romex with the grounds disconnected. I say this because I inspected a home where the owners rewired the house. After testing several outlets and open grounds were found, I pulled the cover off of the panel which was hidden in a cabinet, and discovered that all the grounds were cut! They were present at the outlets when I pulled a few face plates.
Also B as it is G.F.I. protected. I have said before that I don't believe in G.F.I. protection. I would estimate that 50% of the G.F.I. outlets that I test do not function. They either do not trip, do not shut the power off to the outlet that I am testing, or are just stuck and don't work at all.
A majority of homeowners do not even now that they are supposed to test them monthly. I would also like to see the statistics on how many less deaths there are since G.F.I. protection was implemented.
If you were inspecting this home, how would you write it up? Would you write anything up?
-- Eric Van De Ven
Owner/Inspector
Magnum Inspections Inc.
I get paid to be suspicious when there is nothing to be suspicious about!
www.magnuminspections.com
Originally Posted By: dbush This post was automatically imported from our archived forum.
Well, Eric, be quite proud of yourself because you got it right. “A” is the correct answer, it is ACCEPTABLE to have a 2 wire GFCI, not preferred, but acceptable. I don’t remember where, but that is actually one recommended way of “upgrading” 2 wire non grounded systems, but I don’t remember where I read that.
Originally Posted By: Blaine Wiley This post was automatically imported from our archived forum.
I was taught that A was only acceptable if the outlet contained a sticker with the wording “no equipment ground”. Since “A” did not have that wording I answered “B”.
I would agree with you there Blaine.
The question was poorly worded.
Unfortunately, this is the case with a lot of the tests out there. Questions that are ambiguous in nature and therefore, you could make a case for several answers to be correct. Our job is not to determine which is the “best” scenario, but to observe and report on an improper condition.
A better question would have been "Is this allowed"?
The answer is yes, provided the sticker was present.
In the given situation, I advise my clients that although this "fix" is permissible, I would recommend rewiring the home. It may not happen, but if it were my home, I would rewire it.
PS Thanks for the clingy Dave!
-- Eric Van De Ven
Owner/Inspector
