A member of the Awards Committee will post questions at random.
Members may make one post per question thread to answer the questions, and the member’s winning entry must have all parts of the questions answered completely in that one post.
No editing is allowed and INELIGIBLE members will be disqualified.
First correct answers (as judged by the Awards Committee or Poster of the Questions) wins.
Request your choice by emailing fastreply@nachi.org and submitting your Mailing address for shipping.
I observed at least one valley portion of the roof that appeared to have some roofing sealant applied. This may be a temporary repair due to a past leak in this area. Recommend further evaluation by a licensed roofing contractor, and correction if deemed necessary.
A & B & D
Extra: Alan Jackson - Its Alright To Be A Redneck
a) chlorine bleach, b) one part bleach and one part water, c) soap and water & d) vinegar and water
Cork
a) By Shape & b) By Size
The roof has a dead valley, which is a point where two or more parallel roof slopes come together, but has little to no pitch. This will allow for debris and water to collect in this area, drain more slowly or not at all, therefore making the roof more prone to leakage. The shingles in this area are damaged and have been covered with an excessive amount of elastomeric roof coating, possibly due to an ongoing leakage problem. Repair by a qualified roofing contractor is recommended.
a) liquid propane, b) oil fuel & d) solid fuel
EXTRA CREDIT: “It’s Alright to Be a Redneck” by Alan Jackson
size
4.deterioration to framing was observed. Further deterioration will occur is not repaired. A qualified contractor should repair or replace as needed.
liquid propane, oil, solid fuel
Extra: Alan Jackson - It’s Alright To Be A Redneck
crushed Stone. This one is pretty easy to explain! …
Gravel. Gravel is a generally a naturally occurring loose aggregate that has been weathered by water or by rocks colliding. …
Sand. Sand is a very fine aggregate that can be both naturally occurring and manufactured. …
Concrete.
4) Inspection performed:, From the ground ,By walking on roof, With a camera on pole, from the ladder, From adjacent building, From roof edge ,With binoculars ,With binoculars from the ground.
5)Inhale carbon monoxide poisoning comes from fumes and prevent the body from using oxygen properly. A & B & D
I agree with JR, Dead roof Valley. A dead roof valley is where two parallel roofs meet with little to no pitch allowing water and debris to collect, causing roof leaks and other issues. Repair by a qualified roofing contractor is recommended.
A, B, D,
Extra Credit, Alan Jackson, It’s Alright to be a Redneck.
The roof has a dead valley (a point where two or more opposing roof slopes come together but has almost no fall at all) that appears to have been repaired in the past. Recommend a qualified roofing contractor to evaluate.
