Question on Copper Tubing
Exterior copper tubing used to supply gas to the fireplace insert and the bbq grill. Shouldn’t the tubing be protected when going through the wall?
Personally, I’m not a huge fan of flexible tubing running through building materials.
Yes due to expansion and contraction of the building materials.
Needs urethane caulk there as well.
Most jurisdictions won’t allow copper, if it’s natural gas.
seems like this would be asked in plumbing
yes all piping should be sleeve protected with approved material when passing through masonry or concrete
approved sealant choice is personal preference
are you sure? some do, some may not, most is a stretch
codes allow specific type cu
http://publicecodes.cyberregs.com/icod/irc/2012/icod_irc_2012_24_sec012.htm
