Large home, pricy but questioning myself and don’t know why.
Outside service 200 A disconnect: ground, neutral bonding, panel bonding.
Inside RDP with 200A disconnect, but it must be a sub right?
Looks good, but grounds and neutrals intermixed AND a cross bar on the two busses.
I am sure it is wrong, but had to go out and remove the cover a second time on the outside panel to make sure.
Its late and I am second guessing myself.
Right? wrong?
I think your Right .
The point of connection of the equipment grounding conductors, the grounded/neutral conductors, and
the grounded/neutral conductor from the electrical service provider is typically located in the main
distribution panel enclosure unless the main electrical service disconnection device/means is located
upstream (on the line side) of and in a separate location from the main distribution panel enclosure.
The disconnect outside is the service where grounding and bonding take place. The interior is simply a panel with a redundant means of disconnect. The neutrals and grounds need to be separated at the inside panel.
Yes this would be considered a “subpanel” and the neutrals and EGC’s must be separate. Also the feeder to the sub needs 4 conductors.
Thank. Sometimes I look at things that an AHJ is supposed to catch and I just have to ask myself, “am I really seeing this?”
I agree with the above Greg.
And i agree with Greg.
Its a violation, even then I see grounds and neutrals under the same screw.
while not a violation, the fact you have an original panel full of tandems speaks of cheapskate electrician.
I also see MWBC and tandems, make sure all those shared neutrals have 240 volts between hots.
![DSCN6142[1] (Copy).JPG](https://global.discourse-cdn.com/internachi/optimized/3X/4/1/414631cac63af53e3dad8d5872fcb592751d4eff_2_690x500.jpeg)
![DSCN6111[1] (Copy).JPG](https://global.discourse-cdn.com/internachi/optimized/3X/5/d/5df50ec2730e51794c75767ae59746a1398f4208_2_690x500.jpeg)
![DSCN6132[1] (Copy).JPG](https://global.discourse-cdn.com/internachi/optimized/3X/8/1/81184180cb34ff3c292328c2a4d7047bf395af60_2_690x500.jpeg)
![DSCN6143[1] (Copy).JPG](https://global.discourse-cdn.com/internachi/optimized/3X/8/d/8db8ae2a273bc06fb16f2f2a34742f77bd29d68f_2_690x500.jpeg)
![DSCN6112[1] (Copy).JPG](https://global.discourse-cdn.com/internachi/optimized/3X/2/0/20a01559c76701876578bfd176c0cdd0d8222ca6_2_690x500.jpeg)
![DSCN6140[1] (Copy).JPG](https://global.discourse-cdn.com/internachi/optimized/3X/5/a/5a7a1adc7f75c4adba443f69f2e258a725506898_2_690x500.jpeg)
![DSCN6139[1] (Copy).JPG](https://global.discourse-cdn.com/internachi/optimized/3X/3/6/366568d08ac85f5efffd3a9c8b760709ca79b175_2_690x500.jpeg)
![DSCN6137[1] (Copy).JPG](https://global.discourse-cdn.com/internachi/optimized/3X/9/a/9a6887afee9c6f2d49905b8c0d6bdb0b0580a598_2_690x500.jpeg)
