Holes in bearing wall studs (exterior and interior walls that bear the weight of the roof and/or other stories above) may not exceed 40 percent of the width of the stud.
Notches in bearing wall studs may not exceed 25 percent of the stud’s width.
Holes in non-bearing walls can’t exceed 60 percent of their width. Notches in non-bearing walls can’t exceed 40 percent of their width.
The edge of a hole must be at least 5/8 in. from the edge of a stud.
Holes in non-bearing walls can’t exceed 60 percent of their width**.
Notches in non-bearing walls can’t exceed 40 percent of their width.**
I understand the relation to hot tar and built up roofing but still, regardless of the type of roof a pitch pocket is used to waterproof around a pipe.
Yes, pitch pockets are used in many different applications in the industry.
With the long history of use with the hot tar built-up roof applications it has now been used within the building industry many other applications of different type of roof materials.
A pitch pocket **would most likely be used with **a(n)
If d. would have been the answer, the question would have read most likely as (A pitch pocket is mostly associated and used with a )
a. Concrete slump bucket
b. Skylight c. Plumbing stack
d. Hot tar roof
I guess one could debate this until one is blue in the face, but we will leave the correct answer to be at the discretion of the one asking the questions. :)
